What To Do With Wires When Installing Light Switches/plugs - Electrical - DIY Chatroom Home Improvement Forum
Old 09-09-2013, 02:15 PM   #1
Rewards Points: 191
What to do with wires when installing light switches/plugs
This seems pretty silly, but I've installed a few new light switches recently, and I am curious about how the right way to do it is. I've always been told (and read when researching) that you shouldn't install the switches straight into the holes in the back (which our houses builders did, lol). But what Im curious about is putting the wire under the screw. I've come across two kinds of set ups: one with a plate that is immovable in upward direction and a screw that comes up so you can loop the wire around it, and one that is almost exactly the same but the plate moves up.
My question is about the second kind (plate moves up and screw moves up, so there is a space under the plate and screw). Do I loops the wire around the screw and OVER the plate, or loop the wire around the screw UNDER the plate? I've done it under the plate when I've ran into this type of switch/plug and all of the switches/plugs have worked fine. It is kind of a pain to get it under there, though.
However, I'm pretty sure that the plate comes up so you can just jam the wire in there and just screw the screw down. The reason I think this is because for the kind of screw/plug where the plate does NOT move, you can jam the wire in the holes in the back and the plate pushes down on it when you screw the screw down. But I dont know, because in the type with the movable plate the plate doesnt do anything if you put the wire in the holes in the back (those are held in via a spring mechanism or something similar).
Hope this made sense lol. Thanks guys!
amateurplumber is offline   Reply With Quote
Old 09-09-2013, 03:03 PM   #2
joed's Avatar
Rewards Points: 13,332
The ones with plate can actually accept two wires of the same gauge, one on each side of the screw. Push the wire straight in under the plate and clamp it tight. Some of these setup even have hole in the back and look like the pushin style connections. the push in , no screw type, have been known to cause loose connections.
Light Fixture With Multiple Wires Hippy007 Electrical 5 11-01-2012 12:54 AM
Can you use wire nuts on a fan light switch with silvery looking wires? amodoko Electrical 4 10-28-2012 08:26 PM
How do you test a light fixture or bare wires? firsttimeremode Electrical 18 09-18-2012 09:31 AM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 02:44 PM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
