What To Do W/ Ground Wire In Older Home? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-12-2009, 06:37 PM   #16
Licensed Electrician
Magnettica's Avatar
Rewards Points: 150
Send a message via Yahoo to Magnettica
As long as that BX casing is mechanically attached to the metal box there's a 99% chance the box is grounded. I say 99% chance because if the other end of the BX (Armored Cable) isn't mechanically attached to something that is grounded, you don't have a ground. If the box is grounded (we'll assume that it is), then the bare wire in the romex jacket needs to be physically attached to the box so that you will have a sufficient equipment grounding conductor at the fan light. Attach this ground wire to the green screw provided in the fan light.
Magnettica is offline   Reply With Quote
Old 01-12-2009, 06:55 PM   #17
Easy way to check, ohmmeter, jacket to neutral.
rgsgww is offline   Reply With Quote
Neutral Wire? 4x15mph Electrical 8 11-24-2008 01:00 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 01:14 PM
Paint Ground Wire kevin0 Electrical 4 02-10-2008 10:39 PM
wire to a workshop jim c Electrical 11 03-02-2007 03:41 PM
