What To Do W/ Ground Wire Going Into Sub-panel - Electrical - DIY Chatroom Home Improvement Forum
Old 02-16-2013, 04:12 PM   #1
j_sun's Avatar
What to do w/ ground wire going into sub-panel
Hi,
I am in the process of replacing all the knt in my old home. Unfortunately that involves a lot of tearing out of plaster and other tedious things. To help with this process I need to temporarily drop a circuit out of a sub panel in my attic. This sub panel does not have a ground wire connecting it to the main panel. My question is what do I do with the ground wire in the romex I am running into the sub panel for my new circuit? Do I connect it to the neutral or cut it off? The main panel has the neutral and ground busses bonded and is properly grounded w/ ground rods.
Thanks.
j_sun is offline   Reply With Quote
Old 02-16-2013, 04:13 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Originally Posted by j_sun View Post
Hi,
I am in the process of replacing all the knt in my old home. Unfortunately that involves a lot of tearing out of plaster and other tedious things. To help with this process I need to temporarily drop a circuit out of a sub panel in my attic. This sub panel does not have a ground wire connecting it to the main panel. My question is what do I do with the ground wire in the Rex I am running into the sub panel for my new circuit? Do I connect it to the neutral or cut it off? The main panel has the neutral and ground busses bonded and is properly grounded w/ ground rods.
Thanks.
What wiring method was used to feed this sub-panel?
Old 02-16-2013, 04:15 PM   #3
j_sun's Avatar
It's the old style 10/3 romex w/o ground
Old 02-16-2013, 04:16 PM   #4
E2 Electrician
I would replace the feeder going to that panel... no good with that setup. For temporary use, I would GFCI protect the original 10-3 NM if you plan on renovating that area at a later date.... Or just GFCI protect your new temp. circuit...
Old 02-16-2013, 04:20 PM   #5
j_sun's Avatar
Perfect. Thanks. I am planning on replacing the whole setup.
Old 02-16-2013, 04:22 PM   #6
j_sun's Avatar
Btw. What do you recommend I use for the new sub panel? I've got 100A new SquareD main panel with ample breaker space. The sub panel will likely feed 3-4 general lighting and receptacle circuits.
Old 02-16-2013, 04:25 PM   #7
E2 Electrician
just get a sq. d 8 circuit panel if you dont think you'll ever need the room...
Old 02-19-2013, 01:42 PM   #8
ericmunyon12345's Avatar
Hi,
Thanks.
Re run the feed with 3 wire with ground. In the sub panel, the neutral bus bar should NOT be bonded to the panel.
ericmunyon12345 is offline   Reply With Quote
Old 02-19-2013, 01:45 PM   #9
j_sun's Avatar
Hi All,
Thanks for the input. I ended pulling the correct wire from the main panel and installed a brand new SqD sub-panel. I figured if I was going to put some effort into now I might as well do everything the right way.
Jason
Sub Panel over 10g-2 Help Needed hamblinh Electrical 30 01-18-2013 08:46 PM
Routing ground wire from panel to rod novaguy Electrical 5 01-15-2013 05:20 PM
Old Cutler Hammer CH12 panel - ground block GroundLoop Electrical 11 02-15-2012 11:19 AM
Running new(up to code) ground wire & protection. MikeSF Electrical 25 07-04-2010 05:33 PM
sub panel ground and neutral daddyrabbit Electrical 3 01-29-2010 07:49 AM
