-   -   What to do w/ ground wire going into sub-panel (http://www.diychatroom.com/f18/what-do-w-ground-wire-going-into-sub-panel-172107/)
j_sun 02-16-2013 03:12 PM
Hi,
I am in the process of replacing all the knt in my old home. Unfortunately that involves a lot of tearing out of plaster and other tedious things. To help with this process I need to temporarily drop a circuit out of a sub panel in my attic. This sub panel does not have a ground wire connecting it to the main panel. My question is what do I do with the ground wire in the romex I am running into the sub panel for my new circuit? Do I connect it to the neutral or cut it off? The main panel has the neutral and ground busses bonded and is properly grounded w/ ground rods.
Thanks.
stickboy1375 02-16-2013 03:13 PM
12 Attachment(s)
Originally Posted by j_sun (Post 1118431)
Hi,
I am in the process of replacing all the knt in my old home. Unfortunately that involves a lot of tearing out of plaster and other tedious things. To help with this process I need to temporarily drop a circuit out of a sub panel in my attic. This sub panel does not have a ground wire connecting it to the main panel. My question is what do I do with the ground wire in the Rex I am running into the sub panel for my new circuit? Do I connect it to the neutral or cut it off? The main panel has the neutral and ground busses bonded and is properly grounded w/ ground rods.
Thanks.
What wiring method was used to feed this sub-panel?
j_sun 02-16-2013 03:15 PM
It's the old style 10/3 romex w/o ground
stickboy1375 02-16-2013 03:16 PM
12 Attachment(s)
I would replace the feeder going to that panel... no good with that setup. For temporary use, I would GFCI protect the original 10-3 NM if you plan on renovating that area at a later date.... Or just GFCI protect your new temp. circuit...
j_sun 02-16-2013 03:20 PM
Perfect. Thanks. I am planning on replacing the whole setup.
j_sun 02-16-2013 03:22 PM
Btw. What do you recommend I use for the new sub panel? I've got 100A new SquareD main panel with ample breaker space. The sub panel will likely feed 3-4 general lighting and receptacle circuits.
stickboy1375 02-16-2013 03:25 PM
12 Attachment(s)
just get a sq. d 8 circuit panel if you dont think you'll ever need the room...
ericmunyon12345 02-19-2013 12:42 PM
Hi,
Thanks.
Re run the feed with 3 wire with ground. In the sub panel, the neutral bus bar should NOT be bonded to the panel.
j_sun 02-19-2013 12:45 PM
Hi All,
Thanks for the input. I ended pulling the correct wire from the main panel and installed a brand new SqD sub-panel. I figured if I was going to put some effort into now I might as well do everything the right way.
Jason
