What Do These Light Switches Control?!?! - Electrical - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 06:14 PM   #1
What do these light switches control?!?!
Hi all,
I have a panel of 3 light switches of which the middle one controls my outside front porch light. The ones on the left and right don't seem to control anything. I've connected lamps to all of the electrical sockets in the living room to see if they controlled an outlet and it doesn't seem to. So does anyone have any idea how I can figure out what these rogue light switches control?
Thanks all
Ryan
ryan7977 is offline   Reply With Quote
Old 04-06-2012, 07:08 PM   #2
Rewards Points: 350
LOL, I have the same setup! Two switches, I pull them out of the box, they're all wired up, but they do absolutely nothing (best as I can tell).
Like you found, there is only so much testing you can do....I just leave them alone now.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 04-06-2012, 07:11 PM   #3
Ugh! It's just not me to leave that alone ya know? I feel like I MUST KNOW . Oh well, anyone else have any suggestions? If not, I guess I will leave it alone.
Old 04-06-2012, 07:37 PM   #4
Rewards Points: 6,652
Can you please quit turning off and on my lights, and also allow me to raise and lower my garage door. Only way to find out what they do, is by using a Fox & Hound set after making sure that the power is turned off to them.
Old 04-06-2012, 07:47 PM   #5
I have no idea what a fox and hound set are, unless you were being silly.
Old 04-06-2012, 07:49 PM   #6
Do a search on it. It is a nickname for a Tone Trace set, also a trademark name for the same item. As for being silly, yes you have to have a sense of humor when dealing with mystery switches and the such.
Old 04-06-2012, 07:58 PM   #7
Interesting. Thanks for the tip. I'll look into that.
Old 04-06-2012, 08:15 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Do you have burnt out flood lights?
I had customers with several outside receptacles controled by switches for christmas lights.
Old 04-06-2012, 09:27 PM   #9
Learning Things Every Day
Jay 78's Avatar
I also have a set of three switches in my living room near the front door. Top one controls the overhead light in the little foyer area inside the front door. Bottom one controls the outside porch light. The middle one had me stumped for a while before I finally figured out it was for the top outlet of a duplex receptacle.
At the time, I had no idea that it was possible to wire two outlets on one receptacle differently - one always hot, one switched. So if you haven't already, make sure you check both outlets on all the receptacles. I think that's what afci is suggesting.
Under Construction
Jay 78 is offline   Reply With Quote
Old 04-06-2012, 09:28 PM   #10
Ok. Tomorrow I am checking ALL outlets in the living room Across the board again. I'll report results. Thanks for the suggestions all
Need help wiring switches to bathroom light and fan Kid Quick Electrical 31 01-08-2012 08:30 PM
HELP! Wiring 2 switches with new light fixture michugana Electrical 7 04-10-2011 06:49 PM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 06:32 PM
2 switches to same light use 1 for another light gmcclel Electrical 9 05-29-2007 01:30 AM
