What To Do With A Spare Hot Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2013, 09:43 PM   #1
Rewards Points: 160
What to do with a spare hot wire?
I pulled some old wiring from an old range hood we have, but now I have a spare hot wire because of this.
So I have 14-2-2 romex going to a light fixture in the kitchen then it was connected from the light fixture to the range hood using 14-2 cable. Is it ok to cap off the hot wire and be done with it or does it have to be connected to something?
word2yamutha is offline   Reply With Quote
Old 10-22-2013, 09:51 PM   #2
MarginallyQualified
Rewards Points: 2,464
Yes; best practice is to go as far back up the line as you can and cap the unused wire there.
Old 10-22-2013, 09:55 PM   #3
Rewards Points: 13,732
Just make sure it's in a junction box not just laying out in the open.
Old 10-22-2013, 09:58 PM   #4
Rewards Points: 236
yeah. in a junction box, and cap it off. then, if you ever decide to put something there. you already have the wire for it.
Fix'n it is offline   Reply With Quote
Old 10-22-2013, 10:23 PM   #5
Rewards Points: 160
It is currently in a junction box of the light fixture. Dumb question, but since its an active cable it wound't it overheat the cap?
Old 10-22-2013, 11:15 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,360
No it will not !
dmxtothemax is online now   Reply With Quote
Old 10-23-2013, 06:52 PM   #7
Electrician
Rewards Points: 794
Current flow causes heat and since there is no current flow there will be no heat build up.
darren is offline   Reply With Quote
THWN wire; Gray pvc Conduit; and GFCI receptacles Buzzy Electrical 29 09-26-2012 02:41 AM
ceiling fan wicked97 Electrical 4 08-21-2011 08:12 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
