What To Do With Old Stove Cable? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-05-2014, 08:12 AM   #1
Rewards Points: 406
What to do with old stove cable?
There was an oven here but we removed it and now it's just going to be a normal wall. On the other side is a closet so I was thinking of just putting an access panel and leaving the wire the way it is (off at the breaker though). Is this okay? Any other suggestions?
RyanD is offline   Reply With Quote
Old 01-05-2014, 08:21 AM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Pull the wire completely out, or install a junction box facing into the closet with a blank plate.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
Philly Master (01-05-2014), plummen (01-05-2014)
Old 01-05-2014, 09:08 AM   #3
Rewards Points: 13,960
If the wire is not pulled and you go with just a junction box I'd make sure and write what it is on the back side of the cover, remove and cap the wires, on the breaker and mark the wires in the breaker box.
The best way would be to remove the wire as suggested completely.
Old 01-05-2014, 09:08 AM   #4
Licensed electrician
Rewards Points: 1,750
Or install a deep 4 square box with a 2 gang ring and a blank plate near the floor in the wall.
Old 01-05-2014, 10:00 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,226
My preference would be to leave it. Never know when plans change in the future (by you or future owner). Remove the receptacle and put it in a 4" square with a blank cover. Remove the wires from the breaker, cover with wires nuts and label to where they go.
Coastal South Carolina
Old 01-05-2014, 10:19 AM   #6
joed's Avatar
Rewards Points: 13,292
By installing an access panel you should be fine code wise. The wires are in a box and they will be accessible.
Old 01-05-2014, 11:02 AM   #7
Rewards Points: 406
Getting rid of it would be a hassle since I'm sure it's stapled in the walls.
I think I'll disconnect and label at the panel, take off the outlet and put a metal box labeled with nuts and then close it off in an access panel in the closet.
Thanks.
Power cable wire nutted in return duct not in box pex006 Electrical 25 07-15-2013 11:32 AM
Extending and covering phone cable in closet Dorado Electrical 5 03-28-2013 10:09 AM
NM cable and Dual fuel range edge130 Electrical 0 11-02-2011 03:48 PM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 10:20 AM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
