What Do I Need? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 07:08 PM   #16
Electrical Contractor
kbsparky's Avatar
Originally Posted by ryan50hrl View Post
I already switched the plug and outlet.......now I just need to figure out whats going on with the motor....
Nothing. Motors typically use 6 times or more juice to start than they need to run. So-called energy efficient motors need even MORE to get going.
I'd say you're good to go. Unless the motor fails to start, I'd leave the capacitor alone.
-KB
Old 09-12-2012, 07:15 PM   #17
Rewards Points: 164
Well my concern is its dimming the lights in the whole house when I turn it on, my table saw which is a bigger motor doesn't do anything to the lights....
I pulled out the starter capacitor and tested it using this method.... http://www.wikihow.com/Check-a-Start-Capacitor
The one capacitor on the outside of the motor tests fine by this method....the other capacitor reads the same thing every time.....never moves
ryan50hrl is offline   Reply With Quote
Old 09-12-2012, 07:23 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Is this by any chance a 'used' dust collector?
Old 09-12-2012, 07:27 PM   #19
Rewards Points: 164
Yep....why do you ask?
I paid less than 70 bucks for it, so i'm ok spending some money getting it cleaned up....
Old 09-12-2012, 08:17 PM   #20
Rewards Points: 164
So where am I likely to find one of these capacitors around town........this one matches all the specs I need.....I just don't want to wait for shipping....
http://www.amazon.com/Amico-200uF-20...+mfd+capacitor
Old 09-12-2012, 08:36 PM   #21
kbsparky's Avatar
Are you SURE that capacitor is bad? Have you tried using a real capacitor tester?
-KB
Old 09-12-2012, 08:41 PM   #22
Rewards Points: 164
Nope, I haven't.....and for the couple bucks the capacitor is.....i'm ok just trying a new one.....Pretty sure I can't buy a tester for the same price.....LOL
Old 09-12-2012, 08:43 PM   #23
Rewards Points: 164
digging around.....a number of other people have experienced the same thing with this model, and replacing the capacitor fixed it for them...
Old 09-12-2012, 10:37 PM   #24
Rewards Points: 806
You could try spinning the shaft manually then quickly powering on to see if motor runs ok. If so then it's worth a new cap.
curiousB is offline   Reply With Quote
Old 09-13-2012, 11:47 AM   #25
Rewards Points: 164
Ok, so I found a new capacitor, And it defiantly starts better now, but the draw is still high enough at start up to dim the lights. Is it possible to put a larger capacitor on it, and would that decrease draw at startup?
Old 09-13-2012, 06:18 PM   #26
dmxtothemax's Avatar
Rewards Points: 5,182
Originally Posted by kevinp22 View Post
Motors draw more current when they start than running amps. Breakers accomodate this but if the start up phase is too long or draws too much it means (1) the instructions should have stated a 20A circuit or (2) the motor aint quite right.
If you ran 12 gauge cable just make the circuit 20A
should say
"some breakers accomodate this"
I beleive you call them type two breakers.
They are in essence a slow blow type breaker,
used for loads that have a turn on surge such as motors
and transformers.
Normal house hold breakers are fast blow types.
different.
dmxtothemax is online now   Reply With Quote
Old 09-13-2012, 06:42 PM   #27
kbsparky's Avatar
Motor that size, probably ain't going to happen. They draw over 6 times the running current to start, and energy-efficient ones take even more.
You might need a larger power company transformer, or incoming line, or both to reduce/eliminate voltage sag.
-KB
Old 09-13-2012, 06:57 PM   #28
Rewards Points: 164
Ok. So why doesn't my 1.75 hp table saw that's a higher amp draw stated on the motor plate do the same thing? Just tryin to understand this.
Old 09-13-2012, 07:02 PM   #29
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
A lot of the guys over the woodworking site thought that dust collectors need to be on 20 amp circuits here's the motor for my dust collector it will be the only thing on the circuit is a 15 amp circuit with 14 gage wire big enough?
Does it have a factory plug and what does it look like?
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 09-13-2012, 07:03 PM   #30
electures's Avatar
Could be because the table saw is starting with no load versus the vac having more of a load.
