What Do I Need? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 05:27 PM   #1
Rewards Points: 164
What do i need?
A lot of the guys over the woodworking site thought that dust collectors need to be on 20 amp circuits here's the motor for my dust collector it will be the only thing on the circuit is a 15 amp circuit with 14 gage wire big enough?
ryan50hrl is offline   Reply With Quote
Old 08-22-2012, 06:04 PM   #2
Licensed electrician
Rewards Points: 1,600
Your motor draws 12 amps at 120 or 6 at 240 volts.
Old 08-22-2012, 06:11 PM   #3
kevinp22's Avatar
yes, its big enough
kevinp22 is offline   Reply With Quote
Old 08-22-2012, 06:15 PM   #4
Rewards Points: 164
Thats what I was basing it off of, however a number of people told me it should be on a 20 amp circuit......I couldn't see any reason for that.
Old 08-22-2012, 07:11 PM   #5
kevinp22's Avatar
No especially since this wont be on all the time
even if it was, on its own circuit 15 amps is plenty
Old 09-12-2012, 01:23 PM   #6
Rewards Points: 164
Ok....so I wired up a 15 amp circuit.....plugged it in, flipped the switch, the motor starts, and then blows the breaker......try a different 15 amp circuit, blows the breaker.....plug it into a 20 amp circuit....runs fine........why does it say on the motor 12 amp, but still blow the circuit?
Old 09-12-2012, 02:02 PM   #7
kevinp22's Avatar
Motors draw more current when they start than running amps. Breakers accomodate this but if the start up phase is too long or draws too much it means (1) the instructions should have stated a 20A circuit or (2) the motor aint quite right.
If you ran 12 gauge cable just make the circuit 20A
Old 09-12-2012, 02:05 PM   #8
Rewards Points: 164
I ran 14-2 , I guess I'll just convert it over to 220.
Old 09-12-2012, 03:49 PM   #9
kevinp22's Avatar
Sorry. That probably is your best bet. Reindentify the white wire as a hot and move to a double pole 15A breaker I assume it is a "pure 220V" load - no neutral required? If a neutral is needed you cant use the ground. You will have to run a new wire.
We didnt intend to misguide you. Honestly, I cant understand why its tripping but it is what it is.
Old 09-12-2012, 04:44 PM   #10
Rewards Points: 164
No harm no foul......I assumed the 15 amp circuit would be enough too.....anyhow......It'll be cheaper to run anyhow.......
So i've swapped it over, and it runs fine now, however I have a clamp on amp meter and on 110, it was drawing around 80 amps start up for a split second.......on the 220, its drawing 45 or so ( on just one line ).....it draws enough that it dims my lights for a split second which are on another circuit, but on the same 60 amp subpanel. Is it possible that the capacitor is going bad?
Old 09-12-2012, 05:02 PM   #11
Semi-Pro Electro-Geek
Rewards Points: 2,938
Originally Posted by kevinp22 View Post
Sorry. That probably is your best bet. Reindentify the white wire as a hot and move to a double pole 15A breaker or two single 15A breakers tied together with a handle tie. I assume it is a "pure 220V" load - no neutral required? If a neutral is needed you cant use the ground. You will have to run a new wire.
He must use a double pole breaker, not two single pole breakers with a handle tie. Handle tied single pole breakers are only allowed if all loads on a multiwire branch circuit are 120V only. This is a 240V load, so it must be a common-trip double pole breaker.
mpoulton is offline   Reply With Quote
Old 09-12-2012, 05:08 PM   #12
Rewards Points: 164
I used a double pole breaker.......
Anyone care to explain to me how to test a capacitor? I'd appreciate it!!
Old 09-12-2012, 05:30 PM   #13
Rewards Points: 826
You'll need a Nema 6-15 plug if you went 220V/15A. Most home stores sell Nema 6-20s (for 220V/20A) but 6-15 are a little harder to find.
I did this with a compressor a few years ago. Motor starts much better in cold weather at 220V, lower line losses at peak current.
curiousB is offline   Reply With Quote
Old 09-12-2012, 05:31 PM   #14
Rewards Points: 164
I already switched the plug and outlet.......now I just need to figure out whats going on with the motor....
Old 09-12-2012, 07:02 PM   #15
Rewards Points: 164
Ok......pretty darn positive now that its the starter capacitor......where can I buy one locally as i'm assuming these are pretty generic parts?
Its a 200 MFD cap
