What Do I Do If My Transformer Blows Out - Electrical - DIY Chatroom Home Improvement Forum
Old 05-08-2012, 04:54 PM   #1
Red face
what do i do if my transformer blows out
thomaspatt3rson is offline   Reply With Quote
Old 05-08-2012, 04:58 PM   #2
Licensed electrician
Rewards Points: 1,780
What is the transformer for?
Old 05-08-2012, 05:01 PM   #3
Master Electrician
call poco if you have no hydro.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-08-2012, 05:14 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
Replace it.
The Following User Says Thank You to Speedy Petey For This Useful Post:
andrew79 (05-08-2012)
Old 05-08-2012, 05:15 PM   #5
JOATMON
ddawg16's Avatar
Most people fix the cause of the transformer 'blowing out'....
How do you know the transformer 'blew out'?
What does the transfomer look like?
Do you know what blew the transformer out?
Do you know how to replace the transfomer?
ddawg16 is online now   Reply With Quote
Old 05-08-2012, 06:41 PM   #6
biggles's Avatar
install one with a circuit breaker on the low side...pull stat off the ssubbase disconnect the 2 low voltage wires out to the condenser tape off....then repower the furnace/air handler...see if it trips the breakerif the breaker trips the wire run outs to either the condenser or up to stat are shorting out... http://www.bestbuyheatingandaircondi..._Code=TRA3TZ69
Old 05-08-2012, 06:45 PM   #7
Master Electrician
Rewards Points: 3,920
If it's on a pole you're going to need a ladder.....and a hot stick.
brric is offline   Reply With Quote
Old 05-08-2012, 07:20 PM   #8
I=E/R
a7ecorsair's Avatar
Maybe he could get by with climbing spikes and belt
a7ecorsair is offline   Reply With Quote
Old 05-08-2012, 07:28 PM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Disconnect the transformer, unscrew the plates and carefully remove them to expose both coils. Locate fault, unwind, rewind with new wire, replace plates.
This is a DIY site after all.
In all seriousness, it's cheaper to pay some kid in china to do it. Just buy a new one.
Old 05-08-2012, 07:40 PM   #10
Missouri Bound's Avatar
There is absolutely no way anyone can answer this half question.
Do you want it your way or the right way?
Old 05-08-2012, 08:22 PM   #11
Just a DIY guy
That's a fact, jack.
Although I give Speedy Pete an "A" for effort.
M3 Pete is offline   Reply With Quote
Old 05-08-2012, 08:45 PM   #12
The OP logged out the second after starting this thread.
I'm taking bets as to when, and if, they return.
I vote: never.
Old 05-08-2012, 08:47 PM   #13
Rewards Points: 6,652
Hope that it was a Decepticon, and Bumblebee is okay, along with Optimus Prime.
The Following 3 Users Say Thank You to gregzoll For This Useful Post:
a_lost_shadow (05-08-2012), Code05 (05-10-2012), Jay 78 (05-08-2012)
Old 05-08-2012, 08:57 PM   #14
I=E/R
a7ecorsair's Avatar
I don't think the OP even has a problem - yet. The OP said if it blows out. He could just be planning ahead for his hot panel change-out
Old 05-08-2012, 09:44 PM   #15
Learning Things Every Day
Jay 78's Avatar
run!!!!!!
Under Construction
Jay 78 is offline   Reply With Quote
The Following User Says Thank You to Jay 78 For This Useful Post:
gregzoll (05-08-2012)
Low voltage lighting transformer driving me nuts rjniles Electrical 12 01-26-2012 12:18 AM
How do Transformers Connect / Cause of outages (transformer fire) jamiedolan Electrical 23 11-30-2011 05:22 AM
HVAC transformer curtis19 HVAC 8 11-13-2011 06:02 PM
Under Cabinet Lighting -- Where to put transformer? jmai14 Electrical 14 11-13-2011 02:09 PM
How to install Aprilaire transformer? Studly HVAC 9 09-18-2009 09:44 AM
