What To Do With Ground Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 10:43 AM   #1
Rewards Points: 93
What to do with ground wire?
This is a really basic/stupid question but here goes: I just installed a Lutron CFL dimmer switch in a 3-way circuit. The box doesn't have a ground wire, so I capped the ground wire on the switch (per mfg instructions) and installed the switch. When I installed the switch, the bare part of the ground wire near the switch touches the box. Is this a problem? Intuition tells me no, because the ground is supposed to connect to the box anyway, but just wanted to check before I finished installation.
scottyv81 is offline   Reply With Quote
Old 01-29-2011, 10:47 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,872
The ground wire is connected to the yoke/frame of the dimmer. The dimmer is screwed to the (assumed) metal box.
Old 01-29-2011, 10:57 AM   #3
Rewards Points: 93
The ground wire is woven through a few holes in the yoke/frame of the switch. There is a very small length of wire right at the yoke/frame that is bare before the wire insulation starts. It's the bare part of the wire near the yoke/frame that is touching the box that I was questioning.
Old 01-29-2011, 11:06 AM   #4
I understand that, but the box is metal, right? And so is the frame of the dimmer, right? And the wire is attached to the fame of the dimmer, right?
So the exposed section of wire touching is fine since the dimmer frame is directly mounted to the metal box.
Old 01-29-2011, 11:11 AM   #5
Rewards Points: 93
Yep, makes sense, thanks for the help. Like I said, my intuition told me it's OK but I'm an engineer so I tend to over-analyze things.
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 03:29 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 09:20 AM
ground wire debd Electrical 7 04-19-2010 08:05 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
