What To Do With Ground Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2011, 04:38 PM   #1
What to do with ground wire
I have this light fixture attached I'm putting in the storage area of my basement. I'm running 14-2 cable to it. What do I do with my ground wire as there is no ground screw?
Nschieffer is offline   Reply With Quote
Old 09-30-2011, 05:08 PM   #2
I=E/R
a7ecorsair's Avatar
Wind it up and push it up into the box. Plastic fixtures don't require a ground. It the ceiling box plastic?
a7ecorsair is offline   Reply With Quote
Old 09-30-2011, 05:26 PM   #3
Yes, the ceiling box is plastic. I put a wire nut on the end and shoved it inside the box. Thanks for the help.
Old 09-30-2011, 05:31 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Looks like a plastic keyless, no ground required. Coil the ground in the box. Do not do what I have found to often, DON"T CUT THE GROUND OFF!
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
SD515 (09-30-2011)
Replacing outlet - no ground wire clydesdale Electrical 17 12-18-2011 02:29 AM
Ground Location and Wire Size LHB_Texas Electrical 25 05-27-2011 09:38 AM
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
