What To Do With Ground - Electrical - DIY Chatroom Home Improvement Forum
Old 08-30-2009, 07:28 PM   #1
What to do with ground
IN the pic is a ceiling box i have. i am wondering what to do with the grounds with i mount a light. this will be nothing special just a normal "cheaper" light fixture (its a closet). I see that most lights like this only take a hot and neutral. what should i do with the gound.
baum is offline   Reply With Quote
Old 08-30-2009, 07:32 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,878
The only lights I know that don't have a ground are keyless fixtures. That kind of light cannot be used in a clothes or linen closet.
A fixture for closets MUST have an enclosed lamp.
A light with a ground requires the crossbar and fixture be grounded.
Old 08-30-2009, 07:36 PM   #3
what is a keyless fixture?
This is what is used throughout the basement before the "finish" what type do i need for a closet? or hallway?
Old 08-30-2009, 07:39 PM   #4
A keyless fixture is the open lamp white screw-in base. Like you would see in an unfinished basement.
A closet, like I said, needs an enclosed lamp. A hallway does not matter.
Old 08-30-2009, 07:47 PM   #5
so a light fixture like this?
so it needs the brace also?
Old 08-30-2009, 07:54 PM   #6
Yes, and no. You do not need a bar box. The one you have is fine.
Old 08-30-2009, 08:01 PM   #7
Licensed electrician
Rewards Points: 1,272
Watch the clearances. For an incandescent light you need 12" from the plane of the closest shelf to the edge of the fixture.
Old 08-30-2009, 08:28 PM   #8
ao then a fixture like the one in the first pic will have a ground screw on it then?
Old 08-30-2009, 09:55 PM   #9
BCSparkyGirl's Avatar
It will have a ground wire, a small guage bare wire attached to the lumiere. Put this, and the ground from the loomex together under a wire nut. And if you want to get really safe, put a pigtail ground on the mounting bracket, but I find this to be overkill IMO.
BCSparkyGirl is offline   Reply With Quote
Old 08-31-2009, 08:32 PM   #10
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
just a bit of expansion on this but it doesn't change the general answer
a keyless fixture is this:
http://images.hardwareandtools.com/P/5343207.jpg
If you will notice, there is no pull chain on this. There is also a keyed fixture where there is a pull chain switch on the base.
Don't know if it is the real story behind the term but I was told that in the early years of such fixtures, there was a key of some design that would be used to turn the switch and as such, if there was no switch, it would be keyless.
Bonding Ground in Conduit jamiedolan Electrical 5 01-26-2010 11:14 PM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 11:12 AM
Ground question. mystery guest Electrical 5 07-24-2008 01:47 PM
Older home -- Open Ground issues, please help Toyz Electrical 1 06-15-2008 09:41 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
