-   -   What to do with ground (http://www.diychatroom.com/f18/what-do-ground-51985/)
baum 08-30-2009 06:28 PM
1 Attachment(s)
IN the pic is a ceiling box i have. i am wondering what to do with the grounds with i mount a light. this will be nothing special just a normal "cheaper" light fixture (its a closet). I see that most lights like this only take a hot and neutral. what should i do with the gound.
Speedy Petey 08-30-2009 06:32 PM
The only lights I know that don't have a ground are keyless fixtures. That kind of light cannot be used in a clothes or linen closet.
A fixture for closets MUST have an enclosed lamp.
A light with a ground requires the crossbar and fixture be grounded.
baum 08-30-2009 06:36 PM
what is a keyless fixture?
This is what is used throughout the basement before the "finish" what type do i need for a closet? or hallway?
Speedy Petey 08-30-2009 06:39 PM
A keyless fixture is the open lamp white screw-in base. Like you would see in an unfinished basement.
A closet, like I said, needs an enclosed lamp. A hallway does not matter.
baum 08-30-2009 06:47 PM
2 Attachment(s)
so a light fixture like this?
so it needs the brace also?
Speedy Petey 08-30-2009 06:54 PM
Yes, and no. You do not need a bar box. The one you have is fine.
Jim Port 08-30-2009 07:01 PM
Watch the clearances. For an incandescent light you need 12" from the plane of the closest shelf to the edge of the fixture.
baum 08-30-2009 07:28 PM
ao then a fixture like the one in the first pic will have a ground screw on it then?
BCSparkyGirl 08-30-2009 08:55 PM
It will have a ground wire, a small guage bare wire attached to the lumiere. Put this, and the ground from the loomex together under a wire nut. And if you want to get really safe, put a pigtail ground on the mounting bracket, but I find this to be overkill IMO.
nap 08-31-2009 07:32 PM
just a bit of expansion on this but it doesn't change the general answer
a keyless fixture is this:
http://images.hardwareandtools.com/P/5343207.jpg
If you will notice, there is no pull chain on this. There is also a keyed fixture where there is a pull chain switch on the base.
Don't know if it is the real story behind the term but I was told that in the early years of such fixtures, there was a key of some design that would be used to turn the switch and as such, if there was no switch, it would be keyless.
