What To Do About Broken-off Plug Stuck In Outlet? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2011, 07:05 PM   #1
What to do about broken-off plug stuck in outlet?
Looking for advice:
I had an iPod recharger plugged into a kitchen outlet. Yesterday when unplugging the charger from the outlet, one of the two brass blades broke off and remains stuck in the outlet (the other blade, along with the charging device were successfully removed). Would it be a mistake for me to grab the blade that remains stuck in the outlet (with either my fingers or a pair of pliers) in order to remove it from the wall outlet .... without shutting off power to the outlet? Thanks, Jim
Jim Wight is offline   Reply With Quote
Old 11-28-2011, 07:07 PM   #2
Yes, that would not be wise.
Shut off the power
jammin06 is offline   Reply With Quote
Old 11-28-2011, 07:08 PM   #3
Electrician
Rewards Points: 792
Maybe yes and maybe no. If it is the hot side of the plug where it is broken off and you grabbed it with your bare hands you would get a good shock. If it is the neutral side chances are you won't get a shock but no need to take the chance.
Turn power off and pull it out.
darren is offline   Reply With Quote
Old 11-28-2011, 07:11 PM   #4
seansy59's Avatar
Rewards Points: 258
Turn off power.
Pull out with needle nose pliers.
Worst case scenario is having to replace outlet if the prong is stuck deep inside the outlet. But lets try pulling the prong out first.
seansy59 is offline   Reply With Quote
Old 11-28-2011, 08:43 PM   #5
Smile
Thanks - kinda what I figured. I just hate going down into the cellar to shut off the power (not easy access), but thought I'd rather be safe than ..... fried! Guess it's my golden opportunity to replace that bad dimmer switch in the bathroom at the same time.
I appreciate the information and the quick response.
Jim
Old 11-29-2011, 07:44 PM   #6
Missouri Bound's Avatar
Take it as a learning experience. Are the breakers marked in your panel? Are the marked correctly? This is a good time to check that and learn a bit about your home wiring. Many testers and circuit tracers are available for your use. The more you learn the safer you will be.
The Following 2 Users Say Thank You to Missouri Bound For This Useful Post:
Jim Port (08-04-2015), seansy59 (11-29-2011)
Old 11-29-2011, 09:21 PM   #7
joed's Avatar
Rewards Points: 12,420
IF the receptacle is a GFCI then push the test button and it will be safe to pull the prong out. Then reset it.
The Following User Says Thank You to joed For This Useful Post:
Pharon (08-05-2015)
Old 08-04-2015, 07:35 PM   #8
Today when I tried to take my charger out of the socket it broke,so I tried to get it out then I got shoked.
What can I do to get my charger out of the socket without getting shocked?
Kheka is offline   Reply With Quote
Old 08-04-2015, 07:44 PM   #9
Rewards Points: 86
Don't pay the electric bill.
Seriously, I would shut off the power and replace the outlet. They are cheap.
manatee is offline   Reply With Quote
Old 08-04-2015, 08:01 PM   #10
Rewards Points: 750
Well, If a trip to the hospital is less of a hassle than going down into the cellar....Dont worry about shutting off the power. I mean, whichever is the lesser of the two evils.
Hick is offline   Reply With Quote
Old 08-04-2015, 08:04 PM   #11
Licensed electrician
Rewards Points: 1,486
X2 . This doesn't need to be any harder than this.
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 01:04 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
