-   -   What to do about broken-off plug stuck in outlet? (http://www.diychatroom.com/f18/what-do-about-broken-off-plug-stuck-outlet-124926/)
Jim Wight 11-28-2011 08:05 PM
Looking for advice:
I had an iPod recharger plugged into a kitchen outlet. Yesterday when unplugging the charger from the outlet, one of the two brass blades broke off and remains stuck in the outlet (the other blade, along with the charging device were successfully removed). Would it be a mistake for me to grab the blade that remains stuck in the outlet (with either my fingers or a pair of pliers) in order to remove it from the wall outlet .... without shutting off power to the outlet? Thanks, Jim
jammin06 11-28-2011 08:07 PM
Yes, that would not be wise.
Shut off the power
darren 11-28-2011 08:08 PM
Maybe yes and maybe no. If it is the hot side of the plug where it is broken off and you grabbed it with your bare hands you would get a good shock. If it is the neutral side chances are you won't get a shock but no need to take the chance.
Turn power off and pull it out.
seansy59 11-28-2011 08:11 PM
14 Attachment(s)
Turn off power.
Pull out with needle nose pliers.
Worst case scenario is having to replace outlet if the prong is stuck deep inside the outlet. But lets try pulling the prong out first.
Jim Wight 11-28-2011 09:43 PM
:yes:Thanks - kinda what I figured. I just hate going down into the cellar to shut off the power (not easy access), but thought I'd rather be safe than ..... fried! Guess it's my golden opportunity to replace that bad dimmer switch in the bathroom at the same time.
I appreciate the information and the quick response.
Jim
Missouri Bound 11-29-2011 08:44 PM
Take it as a learning experience. Are the breakers marked in your panel? Are the marked correctly? This is a good time to check that and learn a bit about your home wiring. Many testers and circuit tracers are available for your use. The more you learn the safer you will be.
joed 11-29-2011 10:21 PM
IF the receptacle is a GFCI then push the test button and it will be safe to pull the prong out. Then reset it.
Kheka 08-04-2015 08:35 PM
Today when I tried to take my charger out of the socket it broke,so I tried to get it out then I got shoked.
What can I do to get my charger out of the socket without getting shocked?
manatee 08-04-2015 08:44 PM
Don't pay the electric bill.
Seriously, I would shut off the power and replace the outlet. They are cheap.
Hick 08-04-2015 09:01 PM
Well, If a trip to the hospital is less of a hassle than going down into the cellar....Dont worry about shutting off the power. I mean, whichever is the lesser of the two evils.:thumbsup:
Jim Port 08-04-2015 09:04 PM
X2 . This doesn't need to be any harder than this.
