What Is The Difference Between These Two Panels? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 09:36 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
What is the difference between these two panels?
The prices are $47 & $86 iirc
What is the difference between these two panels?-forumrunner_20111113_103158.jpg
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-13-2011, 09:40 AM   #2
the Musigician
DangerMouse's Avatar
More spaces?
"Free" 'starter' breakers?
$39.00?
DM
Old 11-13-2011, 09:40 AM   #3
Licensed electrician
Rewards Points: 1,744
The QO is the high end panel with a copper buss. The breakers also have the Visi-trip indicator that shows a orange flag when tripped.
The Homeline panel has an aluminum buss.
The breakers are not interchangeable between panels.
DangerMouse (11-13-2011)
Old 11-13-2011, 09:46 AM   #4
joed's Avatar
Rewards Points: 13,284
They are both 20 circuit panels. The QO has a copper bus as opposed to aluminum in the homeline.
The homeline is a 'value pack and includes 5 breakers.
The QO
Overhead and underground service feed connections are accommodated with the QO 100 Amp 20-Space 20-Circuit Indoor Main Breaker Load Center. This load center features a copper buss bar and a 22,000 maximum short circuit current rating. This main breaker offers a factory-included combination cover and NEMA type-1 indoor enclosure.
Copper buss bar for excellent conductivity
NEMA type-1 enclosure with a combination cover
Overhead/underground feed with a 2-1/2 in. maximum knockout on top and bottom
Single-phase, 100 Amp , 120/240 VAC, 22,000 maximum short circuit current rating
Compatible with QO breakers and a PK15GTA ground bar kit
Accommodates plug-on secondary surge arrestor
Meets UL and ANSI safety requirements
MFG Brand Name : Square D by Schneider Electric
MFG Model # : 84788
MFG Part # : QO120M100C
The homeline
Square D By Schneider Electric Homeline 100 Amp 20-Space 20-Circuit Main Breaker Load Center Value Pack has an aluminum buss and is suitable for indoor use. The load center value pack includes five 20 Amp single-pole (HOM120) circuit breakers for your convenience. The unit is ANSI certified and UL listed with a maximum rating of 240 volts.
For use as a main breaker load center
Aluminum buss
Single phase
240 volts
Suitable for indoor use
Includes five 20 Amp single-pole (HOM120) circuit breakers
PK23GTA ground bar kit is sold separately
MFG Model # : 88407
MFG Part # : HOMVP5
Old 11-13-2011, 10:45 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
The QO's a Cadillac. The Homeline's a Chevy. Both do the job. The QO has a few nicer features.
Kyle
Neutral path between two main panels EMiller Electrical 13 03-17-2014 07:48 PM
3 phase panels and sub panels michael825 Electrical 32 08-31-2011 08:43 AM
Metal roof over Zip panels Arky217 Building & Construction 1 08-14-2011 10:37 AM
How to flush water heater that has solar panels Homerepairguy Plumbing 2 11-11-2010 08:26 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
