-   -   What are the dangers? (http://www.diychatroom.com/f18/what-dangers-110583/)
Mop in Hand 07-12-2011 11:03 PM
What's wrong with this picture (and why)? When the power goes out and I fire up my 8000 watt generator and plug it into a 30 amp receptical that goes to the main panel for temporary power?
oleguy74 07-12-2011 11:28 PM
if you don't open(turn off)main greaker,you will put voltage back out on the line.since your power to your house is from a step down transformer,say from 13000 volts,you will send gen power back to transformer.when that happems you will put the 13000 volts back on the line.and maybe kill the lineman working on the line.
vsheetz 07-12-2011 11:45 PM
This has been discussed many many times here. One MUST use a main breaker lock-out or transfer switch to ensure safety.
hayewe farm 07-13-2011 12:01 AM
To add you are also using a dead-man extension cord which is very dangerous and in most areas there is a heavy fine if you don't have a main lockout or transfer switch.
mpoulton 07-13-2011 12:33 AM
Your "suicide cord" would be a major danger if someone unplugs it (accidentally or otherwise), since the prongs would be live. The bigger issue, as others said, is that you would be placing linemen and the general public in danger by backfeeding the utility transformer. This is what you get on the high voltage side of a utility transformer when you backfeed it:
http://www.youtube.com/watch?v=eTF7D...eature=related
Because it is both illegal and stupid to connect a generator as you describe, you could be charged with manslaughter (potentially even murder, depending on the jurisdiction) if someone were killed as a result. You would also be civilly liable for any injuries or damages that result.
Just get an interlock.
NJMarine 07-13-2011 05:47 AM
Because it is both illegal and stupid to connect a generator as you describe, you could be charged with manslaughter (potentially even murder, depending on the jurisdiction) if someone were killed as a result. You would also be civilly liable for any injuries of damages that result.
I totally agree.
josall 07-13-2011 09:16 AM
Here is a company that sells a good transfer swiitch
http://www.gen-tran.com/eshop/transf...s-prewired.asp
