What Is Considered "accessible" For A Junction Box. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2008, 10:01 PM   #1
what is considered "accessible" for a junction box.
I want to add a new light fixture. My plan was to cut into a 15 amp romex cable that was near the area, install a junction box, and splice the new romex cable to the new fixture from this box. Is the junction box considered accessable if it's in my attic?
Thanks.
farmerde is offline   Reply With Quote
Old 11-15-2008, 10:10 PM   #2
Rewards Points: 2,350
Thanks.
Yes, it is accessible. But be sure that the circuit you are tapping into isn't a dedicated circuit, or 240 V, or already switched. And it is likely that you won't have the slack to set just one box. You will probably have to use two junction boxes.
Old 11-15-2008, 11:28 PM   #3
When you say as long as it isn't "already switched", it would be o.k. to put something there if I wanted that switch to control the new addition right? For example, I installed a ceiling fan in a room where the switch controlled an outlet. I taped into the switch and now it turns both the outlet and the fan on and off.
Old 11-16-2008, 01:02 AM   #4
Registered User
Termite's Avatar
As long as the portion of the attic that the box is in can be reached by a serviceperson, then you can have it up there. If the attic is a small inaccessible portion, then you cannot have the junction box up there.
Old 11-16-2008, 07:33 AM   #5
As long as you don't put a speed control type switch in for the fan, then sure. If you like the switch and fan to be controlled by the same switch, go for it.
Accessable attic & Junction boxes (NEC question) IvoryRing Electrical 7 04-10-2013 09:30 AM
buried junction box shadango Electrical 28 04-09-2010 04:49 PM
Junction box calculation mind screw Kingsmurf Electrical 1 07-22-2008 11:33 PM
Tie off a run in junction box? NotSoHandyman Electrical 3 05-25-2008 08:36 AM
Junction Question? fw2007 Electrical 10 03-31-2008 11:03 AM
