What Was The Code Requirements On Amperage? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-05-2008, 08:28 AM   #1
What was the code requirements on amperage?
I have a dryer socket rated to 40 amperes and the wire feeding it is 10/3 nm-b and the breaker is 40 amps, this was done by licensed electricians back in 2001. I know this is a violation as you are supposed to use the 60c amperage, not 90c. Was it code back then or not? If it wasn't then is there any tricks to pulling 8/3?
rgsgww is offline   Reply With Quote
Old 09-05-2008, 08:58 AM   #2
Rewards Points: 338
It is permissible to use 10/3 nm-b for a dryer. However, it should be on a 2P30A breaker, not a 40. All of the electric dryers I've ever installed (or seen installed) have been 30A. Check the info on the dryer for the proper sizing of conductors. If it calls for a 40A circuit then you'll have to run 8/3. No special tricks that are different than pulling other wires; Be careful, be safe. pete
petey_c is offline   Reply With Quote
Old 09-05-2008, 09:58 AM   #3
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
I agree with Petey, everything sounds ok except the breaker size. Replace the 40 with a 30.
John
jrclen is offline   Reply With Quote
Old 09-05-2008, 11:33 AM   #4
Thanks for the fast response, I will check the dryer for proper amperage, if it needs 40 (I doubt it) I guess I will be pulling 8/3 but if it just needs 30 then I'll just change the breaker with a 30.
Carrier Furnace help code 31 fauxjaux HVAC 6 04-22-2010 10:36 PM
Code requirements for Vent fan? Indianer Building & Construction 11 06-12-2008 08:30 PM
NC code for Breaker amperage rating in new home for Water Heater, Dryer, Range? lynne Electrical 5 08-26-2007 08:44 PM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 01:47 PM
code question JustJoe Building & Construction 3 01-27-2007 09:06 AM
