Old 08-07-2008, 09:25 PM   #1
What code covers installation of wall heaters?
Does anyone know what code covers the installation of gas wall heaters in Southern California? More specifically, Orange County?
I am aware that installation of water heaters is covered in the California Plumbing Code. Does that cover gas wall heaters as well?
darsunt is offline   Reply With Quote
Old 08-07-2008, 10:50 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
For Electrical, NEC, for Fire, it would be California Code, and the mandates would be covered under NFPA.
gregzoll is online now   Reply With Quote
Old 08-08-2008, 01:56 PM   #3
So you are saying that if the city of Huntington Beach comes out to inspect some electrical work, you have to go strictly by the National Electric Code? Not some code from the state or county?
Old 08-08-2008, 02:05 PM   #4
Or more to the point, to pass inspection installation of a wall furnace must pass regulations from all 3 codes?
Old 08-08-2008, 05:04 PM   #5
Moderator
Termite's Avatar
Hopefully a pro from California will chime in. I'd be cautious about saying that the NEC or International Fuel Gas Code will apply...California is notorious for their codes, and they tend to either amend and add to them, or write their own codes. You need to contact the local jurisdiction to know for sure.
Old 08-08-2008, 05:24 PM   #6
UAW SKILLED TRADES
Stubbie's Avatar
Agreeing here with KC. Your state has the CEC not the NEC, they have several amendments and requirements not found in th NEC. Especially environmental requirements. However I doubt the CEC has much to do with a gas heater installation other than a receptacle possibly. Plumbing codes should be where you need to look.
Old 08-09-2008, 05:12 AM   #7
" Euro " electrician
frenchelectrican's Avatar
I will strongly recomend that you get a ahold of your local inspector in your area due the state of California do have a bit of local addmendments to the regulations.
Unforetally I did not save one of the Californina regulations it was pretty long winded and some case you will say >>
Merci,Marc
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
code for determining retaining wall height mrdol General Discussion 2 11-08-2007 03:47 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
