What Can All Be Included On A Bathroom Circuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 10:45 AM   #1
Rewards Points: 170
What can all be included on a bathroom circuit?
Provided a 20 amp circuit with 12 gauge wire, what can all be included on a bathroom circuit? I am remodeling a bathroom and would like to use a single circuit for the outlet by vanity (GFCI protected), light, and bath fan. I understand the light should not be gfci protected so I would feed the power first to the switch, then pigtail to the outlet with the gfci.
diyer111 is offline   Reply With Quote
Old 08-26-2013, 10:55 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
That's fine.
A 20 amp circuit feeding only one bathroom is allowed to have lights/fan on it for that bathroom.
wirenut1110 is offline   Reply With Quote
Old 08-27-2013, 05:21 AM   #3
Philly Master's Avatar
Rewards Points: 516
we usuallly feed the GFI first then line side to switches ....that device will take the most load
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline   Reply With Quote
Old 08-27-2013, 06:55 AM   #4
Rewards Points: 13,458
Diyer111 I'd suggest going back and adding your location to your profile.
Sure helps when asking code questions.
Just go to quick links to edit.
If you live in Canada those answers my not be correct. They want 15 amp. lighting circuits.
Old 08-28-2013, 09:41 AM   #5
Rewards Points: 170
location has been added
Old 08-28-2013, 09:43 AM   #6
Rewards Points: 170
this is what I would like to do, but I have heard somewhere that gfci's occasionally cause a certain type of light (fluorescent maybe?) not to work, or to flicker....???
Old 08-28-2013, 01:23 PM   #7
Like Philly said, if you feed your switches of the line side of the GFI, you should not have any troubles.
GoldenSparky is offline   Reply With Quote
Old 08-28-2013, 03:57 PM   #8
Rewards Points: 516
using the LINE -- LINE is like using a wire nut .... as apposed to LINE---LOAD .. the LOAD side is GFI protected not the line side
simalar to jumping outlets line in line out to next outlet
Wiring in New Addition? sandyman720 Electrical 6 11-27-2011 03:34 PM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 09:29 AM
Circuit advice for finishing basement Straightgrain Electrical 16 03-25-2009 09:07 AM
Basement Bathroom Circuit design drtpdee Electrical 6 01-03-2008 10:10 AM
