-   -   What can all be included on a bathroom circuit? (http://www.diychatroom.com/f18/what-can-all-included-bathroom-circuit-185958/)
diyer111 08-26-2013 10:45 AM
Provided a 20 amp circuit with 12 gauge wire, what can all be included on a bathroom circuit? I am remodeling a bathroom and would like to use a single circuit for the outlet by vanity (GFCI protected), light, and bath fan. I understand the light should not be gfci protected so I would feed the power first to the switch, then pigtail to the outlet with the gfci.
wirenut1110 08-26-2013 10:55 AM
That's fine.
A 20 amp circuit feeding only one bathroom is allowed to have lights/fan on it for that bathroom.
Philly Master 08-27-2013 05:21 AM
we usuallly feed the GFI first then line side to switches ....that device will take the most load
joecaption 08-27-2013 06:55 AM
Diyer111 I'd suggest going back and adding your location to your profile.
Sure helps when asking code questions.
Just go to quick links to edit.
If you live in Canada those answers my not be correct. They want 15 amp. lighting circuits.
diyer111 08-28-2013 09:41 AM
location has been added
diyer111 08-28-2013 09:43 AM
this is what I would like to do, but I have heard somewhere that gfci's occasionally cause a certain type of light (fluorescent maybe?) not to work, or to flicker....???
GoldenSparky 08-28-2013 01:23 PM
Like Philly said, if you feed your switches of the line side of the GFI, you should not have any troubles.
Philly Master 08-28-2013 03:57 PM
using the LINE -- LINE is like using a wire nut .... as apposed to LINE---LOAD .. the LOAD side is GFI protected not the line side
simalar to jumping outlets line in line out to next outlet
