What Is This Called? (Overhead Power To Detached Garage) - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 01:22 PM   #16
" Euro " electrician
frenchelectrican's Avatar
Are you refering to this type of new overhead quadplex cable like this??
Merci.
Marc
Old 08-11-2010, 01:52 PM   #17
Electrician
Proby's Avatar
Originally Posted by kronic24601 View Post
What would be a proper overhead line if you don't mind me asking ?
I was kind of hoping I could just merge them into 1 cable, something a bit cleaner, but wasn't sure what to do.
Marc posted a picture above. It will look better, be safer, and give you more ampacity out in the garage.
If the insulation on the wires you have up there now is cracking, it's best not to twist them together.
Anything fun is either illegal, immoral, or fattening.
Proby is offline   Reply With Quote
The Following User Says Thank You to Proby For This Useful Post:
frenchelectrican (08-11-2010)
Old 08-11-2010, 02:01 PM   #18
That is one of the most common item I used pretty often on overhead runs run the quadplex that way you can meet the code without any issue at all.
I haven't check the recent price of quadplex overhead cable yet. { For USA side }
You can able get them in 16mm˛{#6 AWG } or larger but 35mm˛{#2 AWG } is most common size I useally order.
The ampacity will varies depending on the distance and size of the conductors.
Old 08-11-2010, 03:24 PM   #19
Ok Pardon my ignorance, But where does the quadplex cable tie into the service entrance? Does it just go up and down, or is it tied off somewhere?
Also, is this common/acceptable to use for a house to garage?
kronic24601 is offline   Reply With Quote
Old 08-11-2010, 03:41 PM   #20
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
How are the wires at the house connected?
They should connect to the panel, and not to the service.
Old 08-11-2010, 03:58 PM   #21
Well there are 2 wires coming out of a hole in the wall. Then the third is just a screw into the metal bracket on the outside of the wall. Then all three (separately) travel across the breezeway and connect to the garage.
It all looks very shady to me.
Old 08-11-2010, 11:07 PM   #22
Pretty close to that and you say 3 exsting conductor some case the middle one is used for traveller for lamp useage { this part is illgeal per modern code due it will switch either hot or netural depending on the 3 way switch postion so if that the case it may be a good time to figure out and ditch that one and do it right }
Merci.
Marc
Old 08-16-2010, 03:02 PM   #23
Photos!
Ok It took me forever to get these (was out of town for the weekend), but here they are. I will be having an electrician come out later today, but just to keep him honest, I thought I see what you guys think
The order of the photos is sorta mis-matched but it goes
1) Garage Entrance
2) Flashing and Pipe I installed, not connected, but I was planning on moving it over there somehow (the pipe still needs to be cut a bit and a Entrance Cap installed)
3) Exit from house (Only two wires coming out of house, the third is just a screw on that metal piece).
4) A Wider View of the Garage Entrance.
What is this called? (Overhead Power to Detached Garage)-img_0836.jpg   What is this called? (Overhead Power to Detached Garage)-img_0834.jpg   What is this called? (Overhead Power to Detached Garage)-img_0835.jpg
Old 08-16-2010, 03:08 PM   #24
I have see that before many time it will be either 120/240 volt circuit OR 120 volt with farmer three way circuit for light { the latter part is illgeal if that the case } OR 120 volt circuit with one light circuit for outdoor luminaires.
So it will be one of the three diffrent set up.
Merci.
Marc
Old 08-16-2010, 03:19 PM   #25
Let me ask this. I'll be running AC, Lights, Misc Tools, And other items ... none specifically requiring 240... but is there some specific setup I "should" have out to the garage? Best practice?
Old 08-16-2010, 03:26 PM   #26
If you going to stay with overhead drop you will need to use the quadplex cable as I show the photo above due teh reason why you will have more than just two circuits in the garage plus what more you will have 240 volts avablile in case you have larger air compressor or welder going to be used in the garage so I know it may cost little more upfront but you don't have to regret it later if you want a 240 volt circuit.
And ., Yeah you will need a subpanel anyway if you going have more than just two circuits IMO It will be the best move if you going go that route otherwise a 4.0mm˛ triple aka 12-3 UF cable with messeger cable to support and use a double pole switch as your disconnect source and after that you can branch out one circuit for lighting and second one is for your receptales.
so there are few ways it can be done depending on big the set up you want.
And I done both overhead and underground verison.
Merci.
Marc
Old 08-16-2010, 03:26 PM   #27
Electrician
Proby's Avatar
Yes, you should have a 120/240V system run out there. It will give you the ability to use 240V tools (compressor, welder) as well as a 240V heater. Even if you never use 240V, having (2) X 120V circuits in a MWBC setup will give you more power for less installation cost.
The exact amount of power you need is up in the air right now, but I personally wouldn't go smaller than #8 wire for a 40A 120/240V subpanel.
You installed that pipe in the roof for the purpose of running the power out to your garage? Where is the inside of the pipe located?
Old 08-16-2010, 04:18 PM   #28
First of all, thanks for everyone advice, this is really helpful. I'll probably want to go with 240 then...
The pipe currently runs down into an empty panel box I installed inside the garage. I was originally not going to install any breakers in the box but perhaps I should?
wiring a detached shed for AC power *and* generator backhaul wrooster Electrical 19 05-28-2010 11:59 AM
House and detached garage need new roofs looking for tips and advice jimtmcdaniels Roofing/Siding 3 11-06-2009 09:07 AM
Mold in detached garage jkrodger Building & Construction 15 05-01-2009 01:46 PM
ENT (Smurf) feeding a sub in detached garage) jamiedolan Electrical 1 02-02-2009 12:52 PM
Light Switch to Detached Garage - Grounding Issue smitty286 Electrical 1 10-22-2008 12:17 PM
