What Is It Called? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-21-2009, 07:56 PM   #1
What is it called?
What is the name of a device that connects two single pole switches together, making them effectively a double pole switch?
yellowdog5 is offline   Reply With Quote
Old 05-21-2009, 07:58 PM   #2
Rewards Points: 2,350
By switches, do you mean circuit breakers? If so, the device is called a handle tie.
Old 05-21-2009, 08:12 PM   #3
Yes, circuit breakers. Thank you!
Old 05-21-2009, 09:04 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
A handle tie.
These are only good in certain applications. This is not the same as a two-pole common trip breaker.
Old 05-21-2009, 09:20 PM   #5
240 volt single or three phase circuits or feeders.
Old 05-21-2009, 09:30 PM   #6
Rewards Points: 150
You can't tie two 110v standard breakers together to form a 220v breaker, since they'd both be on the same leg of your transformer and still be 110v.
220v breakers tie into both legs.
found out the hard way one time, i thought i had smarted out the breaker manufacturers. DOH!
johnnyboy is offline   Reply With Quote
Old 05-21-2009, 10:02 PM   #7
You still trying to cobble that Zinsco panel of yours?
You could have had it replaced by now for under 50 bucks.
220/221 is offline   Reply With Quote
Old 05-21-2009, 10:08 PM   #8
This is only partially true and only for certain breakers. FPE and GE skinny to be exact.
Most others two single-pole breakers WILL give you 240v. Again, a handle tie is not acceptable for this though.
Old 05-22-2009, 11:42 AM   #9
I just realized that the Zinsco bus will accept thin 2 pole breakers.
This is a thin two pole 30 that would fit in your panel. The two pole thin 50 would be the same size. You can do what you want because of the Zinsco style bus.
It's still not real safe to pull out old breakers in this style of panel. They do get stuck and often have to be coaxed out.
Old 05-22-2009, 02:16 PM   #10
Originally Posted by fast1 View Post
what kind of applications?
...or multiwire branch circuits
Willis
williswires is offline   Reply With Quote
Old 05-22-2009, 02:21 PM   #11
On some GE panels you could. But it's STILL not the same as a 2-pole Circuit Breaker! A 2-pole breaker has an internal common-trip mechanism!
spark plug is offline   Reply With Quote
Old 05-22-2009, 02:28 PM   #12
Unless there are also 240v loads a MWBC does not need a "common trip" breaker. A handle tie is sufficient.
This is also only code required under the 2008 NEC. Before that there was NO requirement for a handle tie.
Old 05-22-2009, 04:52 PM   #13
fast1 asked for kinds of applications for the handle tie, and a MWBC is one such application.
Willis
Old 05-22-2009, 05:03 PM   #14
Why, tying handles, of course!
Old 05-22-2009, 05:16 PM   #15
OK, I messed up completely.
You are correct. In post #6 and in my reply to you I was referring to common trip breakers. Not handle ties.
My mind is elsewhere today.
Sorry.
I Called a Plumber, Now I really need Help! kswoot Plumbing 8 10-14-2008 07:57 PM
what is this thing called? farag Plumbing 4 07-28-2008 08:36 PM
Flooring vs Subflooring (whatever it is called) lifeontherun Flooring 3 07-13-2008 03:03 PM
Flooring vs Subflooring or whatever it is called lifeontherun Flooring 10 07-09-2008 08:14 PM
What is this part of the gutter called? DanBress Roofing/Siding 4 11-04-2007 07:41 PM
