What Is This Cable For?? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-18-2012, 01:05 AM   #1
What is this cable for??
I took down my chandelier and there was a cable from the switch that has 1black 1white 1red and 1ground, there was also another cable that was just coming perpedicular from another part of my house that just has 1black, 1white, and 1ground. i am now putting in some recessed lighting and dont remeber how the wiring was connected to the chandelier. what can this other cable be from? any suggestions on how i should wire this to my first recessed light so that all my recessed lighting that i will connect to this first light will work.. so that the lights will turn on and off without having any problems. HELP???
naty0629 is offline   Reply With Quote
Old 05-18-2012, 05:20 AM   #2
Rewards Points: 1,300
Souds like there could be a three way circuit for that light. Is the light controlled from two separate sources? It is also posible that the switch circuit is supplying a neutral to the switch box. How old is this wiring/house. Can you post a picture of the wiring in the box and at the switch?
danpik is offline   Reply With Quote
Old 05-18-2012, 04:29 PM   #3
Master Electrician
was there separate switches for the fan and the light previously?
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 05-20-2012, 10:25 PM   #4
Rewards Points: 1,910
Maybe the 2 wire wg cable is your power in and the 3 wire wg is just a switch leg?
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 08:01 AM
Inside Walls Cable Fishing/Routing tk3000 Building & Construction 9 07-05-2011 08:15 AM
Re-route dryer electric cable Stu27 Electrical 10 09-06-2010 08:21 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 09:10 AM
Coaxial Cable Question bahaisamurai Home Theater 9 08-08-2007 02:54 PM
