What Is The Best Wire Gauge To Use For My New Curcuit? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2013, 01:43 PM   #1
Rewards Points: 27
What is the best wire gauge to use for my new curcuit?
I am rewiring a room in my house and adding a new 15 amp curcuit but i have a question about the guage of romex i should use.
The existing wiring is 14 gouge 2 conductor and has the main hot feed from the panel comming into an outlet in the room and feeding this room, the master BR and the hall way. I am leaving the original outlet feeding the other rooms alone and I am going to split the existing curcuit to sepeate the new room from the 2 others and run the new curcuit for the bedroom i am redoing.
I am installing 1 ceiling fan w/light kit, 4 cannister lights, 1 closet light w/pull chain, 4-5 recepticals and a double outdoor flood light and I was going to use 1 - 15 amp breaker with 14 guage romex. I believe the 15 amp breaker will be sufficiant unless someone thinks otherwise but is the 14 gauge wire acceptable or should I upgrade to 12 gauge with a 15 amp breaker and 15 amp outlets.
VinnyBags is offline   Reply With Quote
Old 05-28-2013, 01:47 PM   #2
jproffer's Avatar
Rewards Points: 702
15A = 14g
20A = 12g
30A = 10g
You should be fine with 14 as long as you plan to use a 15A breaker.
jproffer is offline   Reply With Quote
The Following User Says Thank You to jproffer For This Useful Post:
VinnyBags (07-24-2013)
Old 05-28-2013, 01:59 PM   #3
Rewards Points: 27
Thank you jproffer I was concerned with load. Alot of people are saying to use 12/2 wire ( incase you need more but use it with a 15 amp breaker and 15 amp outlets. Is there still enough load to add to the curcuit in the future if there is a need. I dont want to have to rewire later on when the walls are open now.
Old 05-28-2013, 02:08 PM   #4
jproffer's Avatar
Rewards Points: 702
I wasn't even thinking about the walls being open. In that case, I would put the 12 in now, like you said.
Hard to say if there is capacity for more load, but for the price difference vs. trying to fish it in later...I'd use the 12.
The Following 3 Users Say Thank You to jproffer For This Useful Post:
BirdSlapper (05-30-2013), MTN REMODEL LLC (05-28-2013), VinnyBags (07-24-2013)
Old 05-28-2013, 02:22 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
If you are going to use #12, why bother with a 15 amp breaker.
If you are in the US, most likely you will need an arcfault breaker also.
The Following User Says Thank You to jbfan For This Useful Post:
Old 05-28-2013, 02:33 PM   #6
Rewards Points: 27
Thats what i was thinking. Actually the only reason why i was going to use 14 was because i already had a 100' roll that i never used from a different project. I figured why spend more if i didnt need to but if its better ill use 12. Is the 15 amp breaker and 15 amp outlets ok with the 12 awg wire? The 12 awg can handle a higher load but if there is a need but its fine, right?
Old 05-28-2013, 02:39 PM   #7
Oso954's Avatar
Rewards Points: 420
They are probably the same group of people that think 20 amp receptacles are mandated on 20 amp circuits.
Install a #12, a 20 amp breaker and use the 15 amp outlets.
There is little or no difference in cost between 15 and 20 amp breakers.
15 amp receptacles are rated for 20 amp pass thru.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
Old 05-28-2013, 03:26 PM   #8
Rewards Points: 27
Thanks Oso954 i think that is what I will do. I am putting way to much thought into this. Is the 2 100 wat flood lights also ok on the 20amp circuit or should those be on a sepeate circuit?
Old 05-28-2013, 03:32 PM   #9
jbfan's Avatar
Rewards Points: 140
They are fine.
Old 05-28-2013, 10:25 PM   #10
Licensed electrician
Rewards Points: 1,020
Sorry, no pull chain lights in the closet.
The Following 3 Users Say Thank You to Jim Port For This Useful Post:
frenchelectrican (05-29-2013), jbfan (05-29-2013), VinnyBags (07-24-2013)
Old 05-28-2013, 10:43 PM   #11
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,390
There is more to it when figuring your exact load requirements, but for what you want to do, you are perfectly fine and within 15A (14# wire) parameters.
If it helps you, the relatinship of wattage to amps is Watt= Volts x Amps or if you know watts... then Amps= Watts/120 (assuming 120 V circut).... so your two outside lights are pulling less than 2 amps ...200/120.
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
Old 05-28-2013, 11:02 PM   #12
Rewards Points: 27
Great thank you, that is very helpful. now i just need to figure out the wiring plan.
Old 05-29-2013, 12:59 AM   #13
if you have a roll of 14awg why not run 2 circuits split over 2 breakers??
borrott is offline   Reply With Quote
The Following 2 Users Say Thank You to borrott For This Useful Post:
MTN REMODEL LLC (05-29-2013), VinnyBags (07-24-2013)
Old 05-29-2013, 07:37 AM   #14
jbfan's Avatar
Rewards Points: 140
Missed that.
Old 05-29-2013, 09:59 AM   #15
jproffer's Avatar
Rewards Points: 702
Originally Posted by jbfan View Post
Missed that.
x2 ...good catch Jim
Type and gauge wire to use for project Olcrazy1 Electrical 9 05-29-2013 01:19 AM
10 Gauge wire with 30amp circuit and Baseboard Heat? RocketManZ Electrical 4 12-17-2011 01:19 PM
What size ground wire should I use for 8 gauge power dxmullin Electrical 1 07-06-2011 03:57 PM
Hot Water Heater Wire Gauge bphilip Electrical 16 09-18-2010 08:23 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 10:41 AM
