What Ballast To Use On 2 X T5 Fluorescents In Series - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2009, 04:37 AM   #1
Question
what ballast to use on 2 x T5 fluorescents in series
I have an old UV exposure box that uses 2 x T5 bulbs in series that stopped working. I got replacement bulbs and starters but to no avail.(it uses 2 Sylvania F8W/T5/BL350)
The ballast in the unit has no markings on it.
I have an old unused ballast marked 40W - 1,2m lamp HPF use 3.5uF - Class A4 - can it be used instead?
What would the correct ballast be for this unit
I am very far from places to purchase electrical fittings etc. If it cannot be used - what other plan can I make if any.
kleintoren is offline   Reply With Quote
Old 05-23-2009, 12:00 PM   #2
Rewards Points: 236
I just did a quick search and got way to many hits. Try Googling the lamp number, then narrow it down to the ballast. You may not need that starter anymore. Good luck.
Tags
ballast , fluorescent bulbs , series , ultra violet
Output on Florescent Ballast? aggiesrok Electrical 10 05-08-2009 03:09 PM
Replacing kitchen ballast jknober Electrical 5 10-12-2008 08:48 PM
Installed Fluorescents Not Working prowler 13 Electrical 6 04-08-2008 12:23 AM
please help w/ selection of bad ballast Mack V Electrical 8 10-17-2006 09:54 AM
