What Is This Attached To My Breaker Panel? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-18-2011, 10:30 PM   #16
Not all days are pretty colors..some days are black.
Master of Cold is offline   Reply With Quote
Old 09-19-2011, 02:45 AM   #17
Semi-Pro Electro-Geek
Rewards Points: 2,942
That looks fun to troubleshoot. Which wire goes to the fan contactor coil? Oh, the black one. The condenser overtemp sensor? Yep, the black wire.
mpoulton is offline   Reply With Quote
Old 09-19-2011, 10:10 AM   #18
joed's Avatar
Rewards Points: 12,922
They might be all black but they also probably all numbered if you can find and read it.
Old 09-19-2011, 10:33 AM   #19
" Euro " electrician
frenchelectrican's Avatar
I just got done working on the control panel for large hydraulic press the conductors I did see was all red but it was fun allright most were marked but few were NOT marked so it took little time to sort it out { I have to reconferated the station control plus add a new E stop button along the way }
Merci,
Marc
Old 09-20-2011, 12:24 AM   #20
Reconferated? Surely that word is conneries!
The Following User Says Thank You to mpoulton For This Useful Post:
frenchelectrican (09-20-2011)
Old 09-20-2011, 12:33 AM   #21
however .,, I have to change the lay out for the press operator to use it more easier and add new E stop button per thier companie requirement some dolt did hook up the E stop in parallel that why it got funky.
As far for 99% of the time the E stop circuit always wired in series in N/C fashion only 1% of time in differnt way I not going to comment on the last 1% of conneries.
Merci,
Marc
Old 09-20-2011, 09:46 AM   #22
JOATMON
ddawg16's Avatar
Rewards Points: 1,826
I get to play with pretty wire colors too........and things with pretty lights on them that blink on and off.....oh, and I get to control how much they blink on and off....
Old 09-20-2011, 10:13 AM   #23
Code05's Avatar
Rewards Points: 1,104
Sometimes you never know what you may find.
Code05 is offline   Reply With Quote
Old 09-20-2011, 11:48 AM   #24
C'est no wonder that the mouse will find this warm spot and that is a pain in royal butt to fix if not heeded on it.
Merci,
Marc
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 07:20 AM
Hot water flate rate conversion to breaker panel curlycord Electrical 1 05-06-2009 07:24 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
Portable breaker panel? minameismud Electrical 15 02-24-2008 12:57 PM
