Old 09-17-2011, 01:25 PM   #1
Question
What is this attached to my breaker panel?
I'm rewiring my basement and looking at my breaker panel I noticed a couple of my breakers are double tapped.
One of the double tapped breakers has a refrigerator and a mystery box (see attached) connected to it.
I'm not able to figure out what this box controls by turning the breaker off.
Does anybody know what this mystery box attached to my breaker panel is?
It's got two tiny wires attached with two screws to the left side of it.
inkognito is offline   Reply With Quote
Old 09-17-2011, 01:29 PM   #2
It appears to be a low-voltage transformer, perhaps for a doorbell system?
clashley is offline   Reply With Quote
The Following User Says Thank You to clashley For This Useful Post:
inkognito (09-17-2011)
Old 09-17-2011, 01:36 PM   #3
Thumbs up
Of course - that's it!
Old 09-17-2011, 02:38 PM   #4
Average Joe/ex-Navy IC3
gregzoll's Avatar
What brand of panel? Sqaure D allows for double tap on one specific model panel.
: Now listen, Cadet. I've got a job for you. See this button?
: Don't touch it! It's the History Eraser button, you fool!
: So what'll happen?
: That's just it. We don't know. Maybe something bad, maybe something good. I guess we'll never know, 'cause you're going to guard it. You won't touch it, will you?
Old 09-17-2011, 05:34 PM   #5
Code05's Avatar
I wanna know where you got the hot pink romex?
Code05 is offline   Reply With Quote
Old 09-17-2011, 10:12 PM   #6
San Fransisco?
Master of Cold is offline   Reply With Quote
The Following User Says Thank You to Master of Cold For This Useful Post:
MikeKy55 (09-18-2011)
Old 09-17-2011, 11:26 PM   #7
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by Master of Cold View Post
San Fransisco?
Both of you are close on the answer mais { But } the OP is from Canada and the pink/red NM cable is actually a 240 volt rated cable which it will not have any netural { white conductor } in there.
That typically used on baseboard heater or some case water heater.
Merci,
Marc
Old 09-18-2011, 09:30 AM   #8
I=E/R
a7ecorsair's Avatar
I wonder why it isn't seen in the US...
It sure would be nice for 240 volt work. I had to do a lot of white-wire-taping when I did all my baseboards and thermostats.
a7ecorsair is offline   Reply With Quote
Old 09-18-2011, 09:34 AM   #9
A "Handy Husband"
rjniles's Avatar
It is not required by code here like it is in Canada so no supplier wants to go the expense of stocking it.
And the day you wanted to reuse that cicuit for 120, you would not like it so much
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 09-18-2011, 07:19 PM   #10
joed's Avatar
It's not required by code in Canada either. We can tape the white wire.
It's called Heatex.
http://www.nexans.ca/eservice/Canada..._90_C.html#top
Do not PM with questions that can be asked in a forum. I will not respond.
Old 09-18-2011, 10:43 PM   #11
In such a boring field as electrical work (except for the imminent danger of death) needs a bit of "spark" like a hot pink cables would bring - it is indeed red (thanks crappy digital camera).
Would you look at that, another electrical pun joke - shocking... oops there I go again - just can't seem to switch it off. Damn.
Edit: FYI: The hot pink is for the A/C.
Old 09-18-2011, 10:56 PM   #12
Electrical Contractor
kbsparky's Avatar
Originally Posted by rjniles View Post
It is not required by code here like it is in Canada so no supplier wants to go the expense of stocking it....
99.9% of all circuits I have ever installed using 10-2 romex was for 240 Volt loads. The suppliers here should be stocking black/red conductor romex instead of the black/white stuf ....
Same goes for the 8/2 and 6/2 wire ....
-KB
Old 09-18-2011, 11:21 PM   #13
I work on a/c units. We have all sorts of pretty colors
Old 09-18-2011, 11:26 PM   #14
Hey that looks like a York RTU, right?
Dieselman959 is offline   Reply With Quote
Old 09-18-2011, 11:27 PM   #15
Its a Trane..it was hard to stop.
Apparently it was hard to start too
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Splicing Wires in Electrical Breaker Panel airdaleairdale Electrical 14 06-11-2009 08:20 AM
Hot water flate rate conversion to breaker panel curlycord Electrical 1 05-06-2009 08:24 PM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
Portable breaker panel? minameismud Electrical 15 02-24-2008 01:57 PM
