I have a problem that came on suddenly. Wanted to get some input before I call an electrician. When the refrigerator is plugged in or the washing machine turned on, lamps plugged in on other circuits dim dramatically. The dryer, range, and water heater do not work. However, the dryer makes a buzzing sound when I press the start button and lamps go dark. The red indicator light on the stove comes on but the stove doesn't heat up. I called the power company and they checked the current coming into the house and said it was correct. The technician suggested it might be a bad breaker or a bad leg. Anyone got any idea what this could be?
Sounds like one of the hot legs of your service has gone open. If the POCO checked the power coming in, then the problem is either a bad main breaker or a bad connection on the breaker. If you have a fused main disconnect instead of a breaker, then it could be an open fuse.
Did they open the meter base and check it? Often the bad connection is in the meter base.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
