Wet In Use Outlet Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2010, 06:10 PM   #1
I=E/R
a7ecorsair's Avatar
Wet in use outlet question
On my new house, which box do I use with the Wet In Use bubble? Can I use a standard outlet box or does it have to be a weather proof box? The house has OSB sheathing and it will have steel lap siding.
a7ecorsair is offline   Reply With Quote
Old 10-06-2010, 06:24 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
If the box is installed before the siding, a regular mounted box will work.
If the box sits outside the siding, then a weatherproof box must be used with the bubble cover.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
a7ecorsair (10-07-2010)
Old 10-06-2010, 08:11 PM   #3
Licensed electrician
Rewards Points: 1,020
I like these. Less obtrusive and the same cost as the bubble cover alone.
http://www.arlcatalog.com/Weatherpro...%20Systems.htm
Old 10-07-2010, 10:37 AM   #4
DIYer
The bubble is cheap junk.
Put one on there if you need it to pass inspection, and then change it to a nice solid metal flap cover once you are done passing the code.
Gigs is offline   Reply With Quote
Old 10-07-2010, 10:54 AM   #5
The flap covers are junk
They offer no protection whatsoever
Get a good solid metal bubble cover
Not one of plastic bubble covers
The plastic ones are cheap junk
That low profile recessed in the wall is nice
Old 10-07-2010, 07:45 PM   #6
I=E/R
a7ecorsair's Avatar
Thanks for all the replies and ideas. I will have to look around and see what is out there for approved covers, but my main question was what box I needed to use. My townhouse has a bubble cover and I have one on my garage - they seems OK but not perfect.
GFCI outlet question tripower Electrical 2 06-15-2010 09:27 AM
Outlet and Switch question ich00 Electrical 3 05-04-2010 05:02 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Replacing a section of copper pipe to a Gas Water Heater outlet Question F150dad77 Plumbing 4 10-07-2009 09:32 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
