Wet GFCI - Electrical - DIY Chatroom Home Improvement Forum
Old 01-22-2013, 12:55 PM   #1
Question
Wet GFCI
I had taken off the cover off my GFCI plug in the restroom and I got it wet it started to smoke now there are more plugs that don't work. So I went it out and bought one just got one that looked alike is there different amp in that type of plug I replaced it there is a light that is one the Plug but on power in the outlets. what could be the problem.
DMCM81 is offline   Reply With Quote
Old 01-22-2013, 01:04 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,898
You may have it wired wrong. Exactly what wires are in the box, and how are they connected? Pictures would be helpful.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 01-22-2013, 06:25 PM   #3
There is different GFCIs. 15 and 20 amp. If your wire is 14 gauge it will be 15 amp. If 12 gauge 20 amp. As for it not coming on; make sure the breaker didn't trip; the GFCI must be reset once power is back up (turn breaker off, install GFCI, turn breaker switch on, reset GFCI.
dreamland is offline   Reply With Quote
Old 01-22-2013, 07:33 PM   #4
Rewards Points: 6,652
To add to post 3, a 15 amp is commonly used on both 15 & 20 amp circuits. Only time you would use a 20 amp gfci, is someplace where you are going to use 20 amp devices, that have the one horizontal plug. As for the light, depends on the
The Following User Says Thank You to gregzoll For This Useful Post:
NJMarine (01-22-2013)
Old 01-22-2013, 09:41 PM   #5
Ok here is what I have done and what I bought is this correct let me know here is some pics I see the green light on but no power out the plugs
Wet GFCI-image-1197007046.jpg   Wet GFCI-image-2005928402.jpg   Wet GFCI-image-1372167941.jpg   Wet GFCI-image-2610181869.jpg   Wet GFCI-image-1575972412.jpg
Old 01-22-2013, 09:52 PM   #6
Is that Heatshrink or tape all over the wires that I am seeing? You need to find the Line which is hot, hook that to the Line side. As for why you have two sets of wires to the other terminal, that is also what I am curious about. BTW, the instructions tell you what the light will do if you have it connected correctly or incorrect.
I have both Pass & Seymour & Leviton Pro's in my home. The P&S only light up Red when tripped. The Legrands will be green if on and not tripped, or Green if wired incorrectly.
From Leviton's website:
A line-load reversal diagnostic feature is provided which prevents the GFCI from being reset and stops power from being fed to the GFCI receptacle face or through to downstream devices. A green LED indicator on the GFCI's face also illuminates to alert the installer to the line-load wiring reversal.
http://www.leviton.com/OA_HTML/Produ...minisite=10251
Old 01-22-2013, 09:54 PM   #7
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Have you pushed the test and reset button on the GFCI?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 01-22-2013, 09:58 PM   #8
rrolleston's Avatar
Started to replay and had to step out. Now I see you posted pictures what is up with the shrink wrap tubing? Did you connect this the same way the old one was? Do you have a multimeter?
Old 01-22-2013, 10:09 PM   #9
Yes it's heat shrink and it was already there but I connected the same way I took off the old one.
Old 01-22-2013, 10:11 PM   #10
There is 3 wires on one side and 3 on there and ground on the bottom
Old 01-22-2013, 10:25 PM   #11
rrolleston's Avatar
You will need a meter to verify that the wires are correct it's possible that the connections on the back of this GFCI are different of maybe a wire got moved around.
Old 01-22-2013, 10:28 PM   #12
Thanks I will have to get one
Old 01-22-2013, 10:43 PM   #13
Resi EC
Rewards Points: 252
Look at the back of the old GFCI receptacle, you should see a 'LINE' and a 'LOAD'.
Look at the new one you will see the same, only difference is that the line and load will be different, thus green light no power.
For some reason Leviton has changed the 'LINE' and 'LOAD' terminals, so, (no fault of yours) its wired backwards.
Gac66610 is offline   Reply With Quote
Old 01-22-2013, 10:54 PM   #14
Here is what the old one looks like
Old 01-22-2013, 11:05 PM   #15
Resi EC
Rewards Points: 252
Yeah, 'LINE' on bottom "LOAD' on top.
I'll bet the new one has "LOAD' on bottom and 'LINE' on top.
Reverse your wires and it should work fine.
Turn power off first
Another GFCI Question Jzone99 Electrical 5 09-16-2012 02:56 PM
Replacing kitchen gfci with gfci breakers-something's not right Fpbaum Electrical 14 05-01-2012 09:43 AM
GFCI - White & Black Both HOT? hagler Electrical 11 03-19-2012 09:29 AM
GFCI Question Mdbuilder Electrical 6 06-19-2008 04:15 PM
GFCI questions 5circles Electrical 4 11-05-2007 09:24 PM
