Wet Bar Code - Electrical - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 04:04 PM   #1
Wet Bar Code
Anyone know if a wet bar in a basement needs two 20amp dedicated and protected appliance circuits like a kitchen?
I am wondering if 1 will do, or if there is even anything in code specific to wet bars.
FirstAndTen is offline   Reply With Quote
Old 01-11-2011, 04:53 PM   #2
the Musigician
DangerMouse's Avatar
I moved this to Electrical where you'll likely get a faster answer.
DM
Old 01-11-2011, 05:15 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
a kitchen is an area with a sink and permanent facilities for food prep and cooking.
does your wet bar fall under that definition?
Old 01-11-2011, 08:48 PM   #4
Rewards Points: 324
if it is a wet bar and not part of kit,no outlets required.but if an outlet is there it is req to be gfci if it is within 6' of out side edge of sink.210.8(a)(7)
oleguy74 is offline   Reply With Quote
Old 01-11-2011, 10:41 PM   #5
Electrical Supplier
Rewards Points: 150
Yeah the only thing you need to worry about is GFCI protecting the outlets if they are close to the sink.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 01-11-2011, 10:44 PM   #6
Thanks! That makes sense. Definitely not a kitchen or even a kitchenette. Looks like I'll be fine (at minimum) with just a single GFCI.
error code 45 Turtle learner HVAC 2 01-10-2011 05:09 PM
Need advice; GC's ignorance of code to cost us extra? Merst Off Topic 9 06-12-2010 10:22 AM
code details for boxes kama Electrical 6 01-30-2009 11:25 AM
Distance between Heater & Combustibles DIY_JC Building & Construction 7 01-20-2009 08:52 AM
Another Bryant 383KVA with code 31 problems rpgIVguru HVAC 1 02-05-2007 02:47 PM
