Wet Bar Circuits - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 01:34 PM   #1
Wet Bar Circuits
Hi All, Im planning on building a wet bar in a room on the side of my house. I was wondering if its okay to have '3 Countertop GFCI outlets, One mini fridge, one wine cooler, and a outlet for cable box/av receiver dvd player' all one 20 amp circuit with 12/2 wire?
And as for lighting there is already a ceiling box which im going to use for the pendant lights above the bar overhang. But i need to add another 4 recess lights, should i run a new circuit for them or just branch off from that one ceiling box in that room?
ahatin is offline   Reply With Quote
Old 01-04-2012, 02:13 PM   #2
Julius793's Avatar
assuming it's a regular room I don't see an issue however practically i would run another circuit because there's a good chance your going to need it.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-04-2012, 02:22 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by ahatin View Post
3 GFCI outlets and cable box/av ... all one 20 amp <-- OK
One mini fridge, one wine cooler <-- on another (sized to load)
...to add another 4 recess lights, should i run a new circuit...?
depends on what the total load as it is... but probably
It's about doing better than "wondering if its okay"
hth
Two Circuits Sharing a Neutral brookny Electrical 22 09-12-2011 09:40 PM
Moving multiwire circuits WillK Electrical 5 06-21-2011 07:12 PM
Split receptacles, double pole breakers and multiple circuits in a junction box. morganhammer Electrical 6 04-05-2011 04:38 PM
short circuit. reset the breaker, but no power bp91708 Electrical 10 03-18-2011 10:07 AM
Adding odd circuits in a bedroom and hood fan oh my! beatle Electrical 3 11-19-2009 07:45 AM
