Wet Bar Circuit Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-30-2009, 03:36 PM   #1
Wet Bar Circuit question
Happy New Year to everyone. I'm spending my vacation framing out and hopefully running wiring for my wetbar (9' x 11') which will include an L-shaped counter top over cabinets and bar top counter, 5-6 recepts, an under counter refrigerator, 5 pendant lights, and 5-6 recessed lights.
My question is about circuitry. My thought is to put everything on one 20 amp GFI circuit, with recepts first in the run (including a recept for a plug in under-counter refrigerator) and then the lights.
Is that too much load on one 20 amp circuit. Should I run a dedicated refrigerator circuit? Do I need the 5-6 recepts split between two circuits?
Hoping to finish wiring by the weekend so any advice would be appreciated.
Thanks!
Straightgrain is offline   Reply With Quote
Old 12-30-2009, 04:04 PM   #2
What wattage bulbs will you be using ?
What is the power draw of the fridge ?
What other items will be powered off these outlets ?
TV, blender, microwave ?
I'm setting my bar up with (2) dedicated 20a circuits
Lights will be seperate
I'll actually have a full size stove behind the bar
It will be setup as a complete 2nd kitchen, small fridge tho
Old 12-30-2009, 04:28 PM   #3
40-60 amp bulbs, not sure on the amps for the frig (but I want to play it safe), probable microwave and blenders on the recepts.
Your thoughts/suggestions?
Old 12-30-2009, 04:40 PM   #4
Well 11 lights at 60a = 660w = 5.5a
A small dorm fridge takes about 3.5 a I think
So that is 9a - almost 1/2 the circuit
I took power for my lights off an exisiting light circuit that was under-utilized
We will have a microwave out there
Have a party - 1 or 2 blenders running...some crock pots for meatballs etc
I would run (2) 20a circuits & see if there is a lighting circuit you can tie into for the lights
I would also consider CFL's
I'm using (4) 13w CFL floods in 6" cans over most of the general bar area ~19'x20'
Then (4) 13w 4" cfl cans over the bar - every ~2 = ~10' bar
I will also have acces to a 3rd circuit behind the bar that will be shared with an outlet by the sub around the corner
Then in the general bar are will be 2 more 20a circuits
The other 1/2 of the great room 17'x24' will have 2-3 more 20a circuits
So take into account that party you may have with a bunch of stuff running
Old 12-30-2009, 04:45 PM   #5
If I put the refrig on a recept circuit, does it have to be at any certain point in the recepts (i.e. can it be at the end of a GFI recept run?)
Old 12-30-2009, 05:03 PM   #6
The fridge can be anywhere on the circuit
I'm not sure where ours will end up
Old 12-30-2009, 09:15 PM   #7
Thanks Scuba...greatly appreciate it.
Old 12-30-2009, 09:48 PM   #8
" Euro " electrician
frenchelectrican's Avatar
Just give you a head up wet bar rules is very simuar to Kitchen circuits so you will need minuim of 2 circuits.
Everything under wetbar must be on GFCI.
That including the fridge under the bar.
If the luminaires are above the wetbar like ceiling cans then no you do not need GFCI at all.{ but strongly recomend a dimmer to turn down the lights to suit your mood unless you got CFL make sure they are dimmable }
Any other question just holler one of us will steer ya right way.
Merci,Marc
Old 12-31-2009, 08:11 AM   #9
Merci,Marc
Thanks Marc. I think I'll do 2 recept circuits, one of which will have the refrig recept on it...both circuits GFI.
Need help for circuit panel question vpahandyman Electrical 3 10-09-2009 09:14 PM
Circuit Size Question techinstructor Electrical 12 06-28-2009 08:24 AM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
Wiring Design Considerations Question tjandt Electrical 6 09-26-2006 05:44 AM
