Westinghouse Outdoor Transformer Question - Electrical - DIY Chatroom Home Improvement Forum
Old 10-31-2008, 08:55 AM   #1
I have a Westinghouse outdoor low-voltage lighting system. The bulbs are only .5W each and are almost like an LED rather than a traditional low voltage lightbulb. The transformer broke and I'm looking to find a replacement. I've tried to buy a regular low-voltage transformer and the leds are not compatable. Does anyone know where I can purchase a hi-intensity, 12V, 10W, DC only transformer? I would prefer a unit that has a light sensor.
My contact info is dandimase@cox.net if you have any solutions. Thank you for your response.
Best regards,
Dan
dandy is offline   Reply With Quote
Old 10-31-2008, 09:23 AM   #2
the Musigician
DangerMouse's Avatar
if you have the old one still, take it with you to be sure replacement has the same milliamps as well as the same output dc voltage, they should be fine then. compare new and old milliamps that you have there first, of course. this will most likely not be the problem if they are the same.
DM
Old 10-31-2008, 10:11 AM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Try Google, with the info on the label of the transformer. A transformer with the same input/output ratings will work, though you may have to get a photo-eye sensor and wire it in separately.
Kyle
Old 11-01-2008, 02:53 PM   #4
Hosfelt.com PN 56-957, 12v @ 1A, $6 plus shipping.
They call it an "adaptor."
You supply the weatherproofing.
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
hrv question indep HVAC 3 07-17-2008 11:39 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 10:10 AM
New service Question Onytay Electrical 1 10-24-2007 06:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 11:17 PM
