Well Pump Won't Come On -no Water - Electrical - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 11:17 PM   #1
Well pump won't come on -no water
Turned on the faucet and... no water!!!! .
Checked pressure switch, breakers to pump etc all seem ok. Getting 230v at the controller box ( 1hp Franklin electric 2801084915) Start capacitor seems ok, checked ohms jumps towards 0 the moves to infinity. When I turn the power on the controller box itself will "buzz" a few seconds then stop, but pump does nothing. On checking resistance in lines down to pump I get about 16 ohms R-Y, same for R-B, but I get zero for Y-B. This means some kind of short in cables or motor winding down at the pump I'm guessing? Please verify if I'm on the right track here and if so any idea on general cost to get this replaced on a 300 ft plus well?
Thanks, David
david30281 is offline   Reply With Quote
Old 02-26-2012, 11:29 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
My parents well is about the same depth was 300 something we first thought bad pump because of resistance tests and after replacing the pump and still no water it ended up being a wire so we pulled the dang thing twice. It's two to four person job depending of strength and if I remember right it was over 600 for the stainless steel pump.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-26-2012, 11:29 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
does your pressure switch have a low water cutoff "Arm" on the side of it?
Journeyman Plumber
Old 02-26-2012, 11:55 PM   #4
Idiot Emeritus
Rewards Points: 1,492
The resistance from Yellow to Red could easily be 16Ω, but the resistance from Yellow to Black should be around 7Ω, and the resistance from Black to Red should be the sum of the other two.
Most likely either the run winding in the motor is shorted or the Yellow and Black wires are shorted.
When wires short together, it's almost always near the bottom of the well, usually the splice at the motor has failed.
Rob
micromind is offline   Reply With Quote
Old 02-27-2012, 12:56 AM   #5
No low water arm Alan.
And thanks Rob, that is what I suspected from reading earlier threads on the subject. Now I've gotta decide whether I'm up to pulling it myself or just calling in the pro's.
David
Old 02-27-2012, 11:55 AM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,922
Zero? Definitely not normal. Is it exactly the same "zero" reading you get from touching the two meter probes together? If so, the short from Y to B is either in the pump control box or at the wellhead. The resistance of the wire is high enough that a short at the bottom of a 300' well would read somewhat more than zero resistance.
mpoulton is offline   Reply With Quote
Old 02-28-2012, 07:44 AM   #7
Probably wasn't completely zero but was using a little cheap analog meter and was so close it appeared to be.
So went ahead and had it pulled. Wires b & Y were exposed and one was worn in two from abrasion down near the pump. Thanks to all for the help and info.
David.
Tags
well problem , well pump , well pump control box
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
pool pump fill then dumps water nanderson360 Plumbing 2 10-14-2010 10:58 AM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
