Well Pump Wiring Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-02-2013, 05:03 PM   #1
I have a 3 wire system well pump (red, black, yellow wires to pump) that has a Red Jacket control box and a Square D pressure sensor. Currently the pressure sensor is wired to the primary load center for the house (a 15 Amp 240v breaker). At this primary load center, the neutral and ground share the same bus bar. I want to connect the Square D pressure sensor to a sub-panel that has separate neutral and ground bus bars (the sub panel has been installed for years and is code compliant). I assume the pressure switch "ground" should be connected to the ground bus bar and not the neutral in the sub panel, but want to be sure.
Farmboss17 is offline   Reply With Quote
Old 02-02-2013, 05:17 PM   #2
Licensed electrician
Rewards Points: 1,018
Correct, ground to ground bus.
Old 02-02-2013, 05:22 PM   #3
Thanks for the fast response Jim.
Old 02-11-2013, 11:09 PM   #4
I remodel some one house and this is my first time with this stuff , i have two wire i pump , the wire that come from the pump are , black , white and red , when my guy took the electric off i forgot to take a picture house they wire , can one of you help me wiring this , three wire come from pump , the presure thing and the box it say L1, l2, red, yellow, black thank you for you help
misterteo is offline   Reply With Quote
Old 02-12-2013, 12:48 AM   #5
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Your house or someone elses house and what location?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 12:57 AM   #6
My relative house , in maryland
Old 02-12-2013, 01:03 AM   #7
rrolleston's Avatar
Usually Red and Black are hot L1 L2. But I can't guarantee that it was done correctly. I would be careful working on friends or relatives houses when you are not exactly sure what you are doing.
The Following User Says Thank You to rrolleston For This Useful Post:
oh'mike (02-12-2013)
Condensate pump install question kboorman HVAC 6 07-06-2012 08:54 PM
question about septic pump & alarm wiring. ACR_SCOUT Plumbing 8 02-04-2012 05:19 PM
Wiring a geothermal pump gfmonk Electrical 5 11-14-2009 03:30 PM
Well Pump to Generator Question Sprice Electrical 1 02-11-2009 12:27 PM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 10:10 PM
