Old 09-21-2011, 12:41 PM   #1
Well Pump Wiring
I have a 2 wire 230v submersible well pump. Do I wire from overcurrent protection directly to the pump?
Believer is offline   Reply With Quote
Old 09-21-2011, 12:49 PM   #2
Code05's Avatar
Well Pump Wiring
No, you need a pressure switch and an expansion tank.
Code05 is offline   Reply With Quote
Old 09-21-2011, 12:51 PM   #3
Well Pump Wiring
I bet somebody is going to tell me I need a well and a faucet too. Why do these DIY projects get so complicated. I meant to ask only how to wire the pump. Thanks.
Old 09-21-2011, 12:53 PM   #4
Well Pump Wiring
Dah, on re-reading I understand about the pressure switch. It obviously needs to be in the circuit between power and pump. I guess what I'm trying to ask is do I need any cirucuit protection at the pump.
Old 09-21-2011, 01:04 PM   #5
Code05's Avatar
Well Pump Wiring
No, you need a disconnect. A 2 pole switch will work. Needs to before the pressure switch.
Old 09-21-2011, 01:05 PM   #6
I=E/R
a7ecorsair's Avatar
Well Pump Wiring
You will most likely need some type of disconnect close to the pressure switch.
a7ecorsair is offline   Reply With Quote
Old 09-21-2011, 01:38 PM   #7
Well Pump Wiring
Thanks guys. So I get this clear in my mind, I need a disconnect in addition to (and after) the circuit breaker. Is this correct? If so, is that to get the disconnect close to the pump? Wouldn't the circuit breaker serve as a disconnect?
Power 120V Pump from a 240V circuit RoberTX Electrical 26 07-06-2011 12:43 AM
Swimming Pool Pump & Salt Water Ctlr Wiring brianr Electrical 1 06-27-2011 07:02 AM
heat pump wiring plummen HVAC 5 02-20-2011 09:25 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 12:49 PM
Wiring 240v pump to generator - URGENT Benchr Electrical 4 12-19-2006 06:50 PM
