Well Pump Wires To Pressure Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2009, 08:13 PM   #1
well pump wires to pressure switch
I am working on a house that has a 4" well, there are 3 wires coming out, 1 red, 1 black and 1 yellow, could someone tell me how to wire it to a pressure switch, I am not sure if it is 120 or 240 volts, thanks !!!!
american501 is offline   Reply With Quote
Old 11-30-2009, 08:20 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
You're serious??? You don't even know if it is 120v or 240v, yet you want someone to tell you how to wire it??
Red, black and yellow is an indication of a remote capacitor start. You need a control box along with the pressure switch.
Might I humbly yet strongly suggest hiring someone to do this for you.
Old 12-01-2009, 08:13 PM   #3
Idiot Emeritus
Rewards Points: 1,492
As stated above, this is most likely a 3 wire motor. If so, you'll need a control box. To get the proper box, you'll need to know the voltage and HP of the motor.
If you have an ohm meter that's fairly accurate, and you know the wire size, length, and depth of the well, post the resistance readings. Bla to red, bla to yel, and red to yel.
This will also tell us if it is a two or 3 wire motor.
Rob
micromind is offline   Reply With Quote
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 06:14 PM
Could a failed condensor fan raise pressure/trip high pressure limit switch? (Rheem) hennyh HVAC 6 07-30-2009 02:04 PM
Identifying wires in a three way switch bergs4 Electrical 15 07-29-2009 10:33 PM
3-Way Switch Wiring MrBill_DIY Electrical 8 09-07-2008 05:53 PM
