#16 |
Electrical Contractor
Well Pump pressure switch help needed.
Looks like I nabbed your switch in the last post.
You MUST bring both the line and load wires to the pressure switch in order for it to work. A 2-wire switch loop will NOT work with this switch. Your grounding wires simply wire-nut in the back of the enclosure, since it appears to be plastic.
-KB Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#17 |
That yellow wire is a 12-2 (not 14-2) BTW. Where does it go?
#18 |
It goes to the breaker panel I believe, and then from there to the control box. Looks like I may need an electrician to wire this up.
#19 |
Tell me where the "control box" is? Sounds like they may have configured a 2-wire switch loop from your breaker box, operating a relay in the control box?
#20 |
I'm going to go back under the house and do some looking around and get some wiring info for you guys, I'll post what I find in a bit. This looks like its going to be a bigger job than just replacing the switch.
#21 | |
You talking to me?
Well Pump pressure switch help needed.Quote:
pictures are nice too when trying to describe anything. |
| Display Modes | |
| New pressure switch and inducer and still incorrect drafting | kevintabb | HVAC | 5 | 01-19-2010 01:59 PM |
| well pump wires to pressure switch | american501 | Plumbing | 6 | 12-02-2009 03:29 PM |
| Pressure Switch, Draft Inducer, Burner Box, Problem | majorapus | HVAC | 7 | 10-25-2009 07:14 PM |
| Well Pressure Switch Location | dshcs | Plumbing | 4 | 02-05-2009 10:04 AM |
| Bad pressure switch? | gshock | HVAC | 3 | 11-13-2007 08:15 PM |
