Old 11-03-2010, 03:15 PM   #1
Well Pump pressure switch help needed.
I am currently trying to replace my well tank pressure switch with a digital control one. The line going to the switch is a 14/2 line and the current switch uses a ground line that just screws to the bottom of the switch. The new switch I am installing is a digital switch, it uses the same to leads but does not have a "ground" in it and no where to screw the ground from the line to. So my question is can I install this new switch without using the ground from the 14/2 line? Thanks
slabm7 is offline   Reply With Quote
Old 11-03-2010, 03:49 PM   #2
Just call me Andrew
Do you have a make and model of the switch?
How many wires are on it?
Andrew
secutanudu is offline   Reply With Quote
Old 11-03-2010, 03:59 PM   #3
I=E/R
a7ecorsair's Avatar
What does the direction sheet say that came with the new switch? Connection requirements should be fully covered.
a7ecorsair is offline   Reply With Quote
Old 11-03-2010, 04:51 PM   #4
The new switch is an Amtrol Digital pressure control switch. Model DC2.
The new switch has 4 wires coming out of it. 2 Leads and 2 Lines to the control box. The old switch was a square d and it only used one of the leads and one line to the control box leaving 2 connections not used.
Old 11-03-2010, 04:54 PM   #5
The installation instructions that came with it say very little about the wiring and more about the operation about the switch. It says the switch can be used for 115 and 230 volt systems.
Old 11-03-2010, 05:48 PM   #6
Electrical Contractor
kbsparky's Avatar
Is this your pressure switch? I marked where the ground wires connect.
-KB
Old 11-03-2010, 05:55 PM   #7
No its not, thats the old one that Amtrol had problems with so they developed the DC2, there is not much for info on the internet about it, I've been searching all day.
Mine just has 4 wires coming out the back of it. From Left to right they are Black (Line 1), Blue (Lead 1), White (Line 2), White w/ black striping (Lead 2).
The square d that I took off only uses 1 Lead and 1 Line and the other 2 are left unused. I tried hooking up the Lead 1 and Line 1 to the new switch but don't seem to be getting power to it.
Old 11-03-2010, 06:05 PM   #8
kbsparky's Avatar
Maybe looks like this one?
-KB
Old 11-03-2010, 06:12 PM   #9
Not that one either but close enough, all I have coming out of it is the 4 wires. Any idea how I could wire it up? My 14/2 line has a black and a white with a ground and thats it.
edit, here is a pic on whats going on
Old 11-03-2010, 06:16 PM   #10
kbsparky's Avatar
There should be a mounting plate there, as well as an outer cover.
On the mounting plate, a green screw should be present. Connect your ground wire there.
You should have more than one wire there: An incoming cable from your breaker box, and an outgoing cable to your water pump.
IF your setup is not like that, then there is probably a junction box somewhere nearby where a 2-wire switch loop has been configured. If this is the case, this switch will not work properly.
You will have to rewire it so that both incoming lines connect to the pressure switch, as well as both leads to the pump.
Make sense?
-KB
Old 11-03-2010, 06:18 PM   #11
There is a back plate for the switch but it has no where to attach to copper ground line.
Old 11-03-2010, 06:24 PM   #12
nap
You talking to me?
nap's Avatar
what is the voltgae of your pump?
If there is no attachment point for the ground in the switch at all, simply connect it to the ground going to the motor.
Old 11-03-2010, 06:26 PM   #13
kbsparky's Avatar
Is this your switch?
-KB
Old 11-03-2010, 06:29 PM   #14
The voltage for the pump is 240v.
Old 11-03-2010, 06:30 PM   #15
Yep thats it
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 01:59 PM
well pump wires to pressure switch american501 Plumbing 6 12-02-2009 03:29 PM
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 07:14 PM
Well Pressure Switch Location dshcs Plumbing 4 02-05-2009 10:04 AM
Bad pressure switch? gshock HVAC 3 11-13-2007 08:15 PM
