Well Pump pressure switch help needed.
I am currently trying to replace my well tank pressure switch with a digital control one. The line going to the switch is a 14/2 line and the current switch uses a ground line that just screws to the bottom of the switch. The new switch I am installing is a digital switch, it uses the same to leads but does not have a "ground" in it and no where to screw the ground from the line to. So my question is can I install this new switch without using the ground from the 14/2 line? Thanks
Do you have a make and model of the switch?
How many wires are on it? |
The new switch has 4 wires coming out of it. 2 Leads and 2 Lines to the control box. The old switch was a square d and it only used one of the leads and one line to the control box leaving 2 connections not used. |
1 Attachment(s)
Is this your pressure switch? I marked where the ground wires connect.
Mine just has 4 wires coming out the back of it. From Left to right they are Black (Line 1), Blue (Lead 1), White (Line 2), White w/ black striping (Lead 2). The square d that I took off only uses 1 Lead and 1 Line and the other 2 are left unused. I tried hooking up the Lead 1 and Line 1 to the new switch but don't seem to be getting power to it. |
1 Attachment(s)
Maybe looks like this one?
1 Attachment(s)
edit, here is a pic on whats going on |
There should be a mounting plate there, as well as an outer cover.
On the mounting plate, a green screw should be present. Connect your ground wire there. You should have more than one wire there: An incoming cable from your breaker box, and an outgoing cable to your water pump. IF your setup is not like that, then there is probably a junction box somewhere nearby where a 2-wire switch loop has been configured. If this is the case, this switch will not work properly. You will have to rewire it so that both incoming lines connect to the pressure switch, as well as both leads to the pump. Make sense? |
There is a back plate for the switch but it has no where to attach to copper ground line.
what is the voltgae of your pump?
If there is no attachment point for the ground in the switch at all, simply connect it to the ground going to the motor. |
| All times are GMT -4. The time now is 02:51 AM. |
