Well Pump Pressure Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2012, 03:13 PM   #1
well pump pressure switch
The well pump pressure switch is constantly on the "ON" position. It doesn't matter if no one has the faucet "on" in the house it will stay running outside. I put a new pressure switch and a pressurized tank it still is doing the same thing. Can someone tell me what else can I do to solve the problem that I have.
Schael is offline   Reply With Quote
Old 11-11-2012, 04:34 PM   #2
Electrical Contractor
kbsparky's Avatar
Purge the water line that connects to the pressure switch.
It is most likely clogged, preventing the switch from knowing how high the pressure is.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
micromind (11-11-2012)
Old 11-11-2012, 05:45 PM   #3
Idiot Emeritus
Rewards Points: 1,492
Could also be that for whatever reason, the pump cannot attain the cut-out pressure the switch is set at.
micromind is offline   Reply With Quote
Old 11-11-2012, 07:49 PM   #4
" Euro " electrician
frenchelectrican's Avatar
What kind of pompe ( pump ) you have in there??
Shallow well with pompe above ground
Submergeable well with pompe underground in the well.
There is differnce on them when they are stuck on.
Shallow well verison ( deepwell two pipe pompe is suimuair ) common curpits:
A) Leaking connection on suction side
B) Leaking connection on discharge side
C) Leaking pipe if ran underground
D) Clogged suction screen on shallow point pipe
Submergeable well common curpits:
A) leaking discharge pipe ( this can be multi leaks if hunged by plastique pipe only but steel pipes it can leak thru the threads )
B) Pitless adpatiur leaking. That is special item they used on submergeable well unit which they will translated from internal pipe to the underground pipe to the building.
C) clogged screen on bottom of the well casing
For all above the other common item is low water level or low water flowage
So it will make the differnce so start at the source and go from there.
One thing for sure from time to time if you have hard water or slilty type water it can wear the impeller out fast.
Hope that help ya on this one
Merci,
Marc
Old 11-11-2012, 08:16 PM   #5
Rewards Points: 1,192
I've seen on deep well pumps where they used galvenized fittings at the pump where they rust and leak.
bobelectric is offline   Reply With Quote
Boost Pump for Improved Water Pressure ralphfravel Plumbing 2 08-04-2011 07:33 AM
low water pressure from well pump supply dolfan13jmb Plumbing 4 03-03-2011 01:28 PM
New pressure switch and inducer and still incorrect drafting kevintabb HVAC 5 01-19-2010 12:59 PM
well pump wires to pressure switch american501 Electrical 2 12-01-2009 08:13 PM
New tank new pump, no pressure?? Toyz Plumbing 2 07-26-2008 07:38 AM
