Well Pump Not Coming On - Electrical - DIY Chatroom Home Improvement Forum
Old 09-12-2010, 07:03 PM   #1
well pump not coming on
I am having an intermittent problem: my well pump doesn't always kick on when the low pressure cutoff is reached, the pressure gauge just drops to zero and there is no water flow. I have to lift the lever on the pressure switch to kick the pump on and get water. Does anyone know why this is happening or how to fix it? Thanks for any suggestions.
mazzycat is offline   Reply With Quote
Old 09-12-2010, 07:15 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
could be a worn out switch or it could be the little riser tube to the switch is blocked. Those are my first best guesses.
Old 09-12-2010, 09:55 PM   #3
Dirty contacts in the switch or the riser tube is blocked
hayewe farm is offline   Reply With Quote
Old 09-12-2010, 10:24 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Did you have low pressure cut out switch in the pressure switch ??
If so it will be good time to clean out the small pipe from the pressure switch to the main pipe you will find alot of gunk in there.
If clean then just get new pressure switch if you can find low pressure cutout switch otherwise a standard pressure switch will work just fine but make sure you use the same pressure rating due they do come in 3 maybe 4 diffrent pressure setting.
Merci.
Marc
Old 09-13-2010, 06:03 PM   #5
Thanks for the suggestions. I have tried two different low pressure cut-off switches with the same result, but will check the riser tube for any accumulated gunk.
what's worse - pump cycling or running continuously? rtoni Plumbing 5 06-18-2012 09:06 PM
Replacing basement sink pump kornfein Plumbing 0 04-23-2010 12:56 PM
Shallow well pump issues, spinnb7 Landscaping & Lawn Care 1 04-13-2010 01:04 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
