Well Pump Control Relay - Electrical - DIY Chatroom Home Improvement Forum
Old 09-30-2010, 04:39 PM   #1
What colors do I plug into the L1 and L2? I have Black, Red, White and Ground coming from my panel. From the well pump, they are labelled in the control box Black (B) Yellow (Y) Red (R). That one is easy. Trying to wire my well pump to this Controller.
millerman40 is offline   Reply With Quote
Old 09-30-2010, 04:45 PM   #2
Electrical Contractor
kbsparky's Avatar
Check the voltage rating of the pump. IF it requires 230-240 Volts, then
L1 = Black
L2 = Red
You probably do not need to use the white wire with this equipment.
-KB
Old 09-30-2010, 04:59 PM   #3
That is what I thought, however, what do I do with the white wire, just put a merrett on it and leave it inside the control box?
Old 09-30-2010, 05:47 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
Typically a 240 VAC submersible pump with a control box requires 2 hots from the panel through the pressure switch to the control box. So connect the black and red to L1 & L2. Put a wire nut on the neutral (white wire) at the control box and the circuit breaker panel. All 3 wires to the well pump must be connected at the control box.
Coastal South Carolina
Old 09-30-2010, 06:16 PM   #5
OK, excellent. Thanks for the help everyone.
Re: Pump Control test Franklin msenkpiel Electrical 1 08-04-2010 07:22 AM
Need help from control guys or heat pump gurus (reversing heat pump defrost cycle) pomelo HVAC 11 03-08-2010 08:13 PM
well pump control box HAWKMAN Electrical 6 08-10-2009 11:37 AM
Irrigation pump relay rdy2go Electrical 2 06-01-2009 09:42 PM
Well pump control box delema freeonthree Electrical 36 11-02-2008 09:55 AM
