#1 |
Welder Receptacle - What Electrical Box
I am installing a 30A 240V receptacle for a welder in my attached garage. I have installed 10/2 Romex wire and purchased a NEMA 6-30R receptacle and device cover plate that has 4 screws in it.
My question is what electrical box do I need to install? The flush mount receptacle is 1.5 inches deep. I am in Canada and calculated box fill to be: Conductors (2x2.25) = 4.5 cu.in Receptacle (1.5 in x 5 cu.in/in of depth) = 7.5 cu.in Ground (N/A) = 0 cu.in TOTAL = 12 cu.in I originally wanted to install a 4x4 box with a single device cover. The receptacle fits into this device cover fine, but the cover plate doesn't seem to fit properely. The 4x4 single devide cover interferes with the 4 cover plate screws that attach the cover plate to the receptacle. The other alternative I thought of was to use a surface mount utility box (4"x2-3/8"x1-7/8" deep) and flush mount it. This box has a volume of 16.5 cu.in. The receptacle fits in fine and the 4x4 cover plate screws on fine too. Is there any reason I can't, or shouldn't, use this box? What are my options? Thanks |
#2 |
I=E/R
I just picked up a plastic "high voltage" box that has screw spacing to work with dryer four wire receptacles. Not sure what is available where you live.
#3 |
Thanks. What size is the box?
#4 |
Licensed Electrical Cont.
I use a deep 2-gang nail on device box for this. The receptacle has four holes that line up with the four device holes in the box.
| The Following User Says Thank You to Speedy Petey For This Useful Post: | SNAFU (10-26-2010) |
#5 | |
Welder Receptacle - What Electrical BoxQuote:
I never thought of this, but I put two single gang boxes together as a test and this will work perfect. Thank you very much. I was loosing sleep over this. Now its off to Home Depot to get the correct box.
| Display Modes | |
| 5th wheel electrical receptacle | House2488 | Electrical | 8 | 08-30-2010 02:22 AM |
| Post mounted electrical receptacle | ¯¯NI¯l¯RO¯¯ | Electrical | 13 | 04-19-2010 03:20 PM |
| Electrical outlet receptacle questions | Wolftrap | Electrical | 27 | 06-15-2009 06:44 PM |
| Electrical receptacle problem | centralhome | Electrical | 13 | 12-27-2008 02:45 PM |
| replacing an old Electrical receptacle | djtjak43 | Electrical | 3 | 08-28-2008 08:46 AM |
