#1 |
Welder outlet question
I am installing an outlet for a welder in a new garage. I do not have the welder, however anticipate getting one in the future. In looking at the large, 220v outlets, there are so many different configurations. Can someone tell me which one is most common on the newer welders? I want to put the right outlet in. thank you
#2 |
Licensed Electrical Cont.
Install a NEMA 6-50R receptacle, fed with 6/2 NM, on a two-pole 50 amp breaker.
This is by far the most common welder receptacle.
Sometimes I feel like if I answer any more questions it is like someone trying to climb over a fence to jump off a bridge and me giving them a boost. |
#3 |
Do you have the specs for the new welder. Voltage, Amps? Does it come with cord and plug already installed? I would find out these things before installing anything.
You could bypass the receptacle alltogether by hardwiring it. Speedy's is the norm. But you might want to be certain what you are getting before you install anything. If your going to do it now, use the deepest box you can find. You will be glad you did. Also, you can buy what they call a twist lock receptacle. You will need a twist lock plug. |
#4 |
thanks guys. i appreciate the help
| Display Modes | |
| Wiring a switch, power from outlet | Big Bill | Electrical | 4 | 09-15-2007 04:59 PM |
| adding 20amp outlet for for welder | Geophile | Electrical | 12 | 05-03-2007 09:17 PM |
| Question on GFI outlet | HDoc | Electrical | 3 | 09-18-2006 10:38 PM |
| Adding an aditional outlet outside question | BCULP2 | Electrical | 13 | 06-27-2006 12:00 AM |
| European 220V outlet "Schuko" | estophile | Electrical | 6 | 08-27-2005 09:45 AM |
