Weird Thing I Noticed While Changing Plugs - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-01-2009, 06:42 PM   #16
BCSparkyGirl's Avatar
[quote=InPhase277;322490]
Originally Posted by nap View Post
She's a vinyl wearing, fat, hairy, lot lizzard, Pakastani, white girl from Canada. We have to cut her some slack.
That gets you hot just saying it......
BCSparkyGirl is offline   Reply With Quote
Old 09-01-2009, 07:18 PM   #17
Rewards Points: 1,494
>>> It is easier to pull one from the closest receptacle, or whatever, than to pull a new wire all the way back to the panel in a finished place.
1. You could pull both hot and neutral from the receptacle and connect that to the portion of the circuit in question after making sure both the original hot and its accompanying inoperative neutral have been disconnected.
2. You might double check all the receptacles etc. on the original daisy chain feed to see if you can find the problem with the neutral. Notably convert push-in-and-stick connections (backstab connections) to screwed on connections.
KO plugs are dangerous! Ultrarunner2017 Electrical 10 11-25-2008 06:57 PM
